Looking for Cams that produce good Low end TQ ..
I don't get to the track all that often (twice a year maybe) .. I do enjoy the road a little bit though ... Looking for a cam to go with either the Patriot LQ9s or the 5.3L stage IIs.
I currently have the G5 cam which for cam only puts up pretty good TQ numbers at about 380rwtq....
What are some options out there putting up good tq numbers as well as fairly good HP numbers with these heads.
Also , does anyone have some dyno numbers (or graphs would be good) .. with these heads an no OPEN cutout ..
thanks,
Crowley
thanks,
Crowley
The differences in the heads you are looking at is kind of unique. One is gonna raise compression and one will drop it (all else staying the same, of course). Most of the 222-224 cams are making good torque down low. The bigger ones may be better up top, but they may not be as potent down low. Ask around...I'm sure you'll get more feedback.
Thanks for the replies .. I'm actually looking for something larger than my current G5 cam, but doesn't sacrifice alot of the LOW END that some of these bigger cams might ..
thanks,
Crowley
thanks,
Crowley
LSX Mechanic
thanks,
Crowley
thanks,
Crowley
How much advance does your cam have? Might want to try advancing the cam and bringing your ICL down. That's going to move your powerband lower and more TQ numbers lower in the rpm range. I would suggest this before buying a bigger cam, which is NOT going to give you the low end TQ you want.
josh
Originally Posted by Damian
If you want to go bigger than the G5, you're getting to a point where you cannot have your cake & eat it to..IE: Can't have both bottom and top. Bigger cams make the most power in only one place, HIGH rpm's.
josh
josh
This is exactly why I went with my 224.
Originally Posted by DG Gordon
Go with the 224 cam 581 lift 112 ls from Texas Speed. I just had that cam and it had big time low end.
How the (0, +2, +4, etc) will effect this as do other supporting mods.
The LSX intake might respond differently etc..
I went with 228/228 .588 112LSA. I've seen a lot of people go with 224 and 230, so I went with something in between the two I can't find anyone that has this cam to see what numbers were made, hopefully I picked something good. I'll find out soon enough.
