Need someone to crosscheck me
Old 08-31-2009, 05:23 PM
1313of1600's Avatar
Default Need someone to crosscheck me
Ok So i have my heads and Cam, here is the thing. I have LS6 Ported heads the valves are stock LS6, the springs are the Comp 977's. The Cam im putting in is as follows:
Duration@ .050 236/242 .601/.610 on 114. Will this all work?? Im not sure if these springs can support the cam?
Old 08-31-2009, 05:25 PM
JPH
JPH's Avatar
Ya. Why and how are you getting that #977 spring to fit in that head without maching the spring pockets? A 921 spring kit would have been a better choice.
Old 08-31-2009, 05:36 PM
1313of1600's Avatar
Bought the heads with the springs already installed. Kinda Stuck with them. Can i expect floating Valves above 6300?
Old 08-31-2009, 05:43 PM
JPH
JPH's Avatar
I believe coil bind will be an issue. The #977 spring coil binds @1.195 and if your in at 1.800 with .610 lift max, your binding man.
Old 08-31-2009, 05:44 PM
1313of1600's Avatar
Ok well then what options do i have, the heads have been machined already??????????
Old 08-31-2009, 05:47 PM
JPH
JPH's Avatar
Pop a spring off or 2, and see what installed height there in at. Usually the #977s go in @1.850, so if there right there or close to it your safe.
Old 08-31-2009, 05:49 PM
1313of1600's Avatar
Ok how do i measure that????
Old 08-31-2009, 05:51 PM
JPH
JPH's Avatar
1.800-.602= 1.198 .003 clearance
1.800-.610= 1.190 -.005 clearance (binding)
1.850-.602= 1.248 .053 clearance
1.850-.610= 1.240 .045 clearance (tight)
.050 is recommended coil bind clearance per manuf.
JPH
JPH's Avatar
Snap guage along with dial calipers or a height mike?
Old 08-31-2009, 05:52 PM
1313of1600's Avatar
No i mean what do i measure to find out if im a 1.8 or 1.85?
1313of1600's Avatar
Nevermind gotcha thanks!!!!
Old 08-31-2009, 05:54 PM
JPH
JPH's Avatar
Yup, anythime man.
Old 08-31-2009, 09:33 PM
1313of1600's Avatar
Ok so do i measure from where the machining is to the top? Where are the 2 points im measuring from???
What options do i have if i end up having to switch springs with the heads already machined??
Old 09-01-2009, 11:12 AM
JPH
JPH's Avatar
Measure from bottom side of the outter lip of the retainer to the top of the spring seat locator. And change the whole setup.
Old 09-01-2009, 11:20 AM
1313of1600's Avatar
Change the whole set- up to what now that the heads have been machined what are my options for springs?? I measured from the base where the machining was cut down to, too the top of the spring its-self. That came out to 1.800 on the botton.
Old 09-01-2009, 04:57 PM
1313of1600's Avatar
Started new thread for the new issue.
https://ls1tech.com/forums/generatio...-part-2-a.html
