Support mods for larger cam
Old 09-05-2009, 10:11 PM
BigBadVoodoo Daddy's Avatar
Default Support mods for larger cam
Ok guys excuse my ignorance but I'm curious about this....after reading some threads people have made it sound like if u step up to a pretty large cam, you're gonna need bigger fuel injectors. Is this correct or am I misreading it and one has nothing to do with the other?
Old 09-05-2009, 10:51 PM
JS01's Avatar
If you are making more power you are going to be using more fuel, which means your injectors are going to be working harder.
You will be close to/or max out the stock 26lb/hr injectors in a large cam-only application most of the time. Just make sure and tell whoever tunes the car to pay attention to the injector duty cycle % and tell you what it's at.
Old 09-05-2009, 10:53 PM
ttranssam's Avatar
ya today i some how had a injector break on me....im 104% duty cycle at the numbers below....cams a 240's
Old 09-05-2009, 11:48 PM
TransAmcoupe98's Avatar
Yes, you need to upgrade the FI's. You can potentially leave more power on the table if you don't. I've seen from other post you want to use an MS4. I would recommend some 37#. That way of you do heads down the road, you still have a cushion but not too much.
Old 09-06-2009, 10:55 AM
VIPERKLR's Avatar
id just get a set of 42s they will be cheaper and if u ever upgrade you will be ready
