Do I upgrade the timing chain on an LS1?
there are many choices out there, you could look at some of our sponsors and find one. I personally think that byunspeed (they are a sponsor here) has some good prices on rollmaster's double roller timing chains. I would consider my options, but as supperspeed pointed out if you are replacing it you might want to upgrade.
Here are some pics I took during my build of the LS1 next to the LS2 chains. Look closely and you will see wich one is the better choice. I personally went with the Katech C5R chain but I am turning beyond 7K rpm's.
Guess who just used the search feature....
<< This guy right here.
Related question: Have a 55K mile motor that went forced induction about 20K miles ago and I'm about to do a cam swap. Is it necessary to upgrade the timing chain? If I do the upgrade, do I need just the LS2 chain or do I have to get the gear set as well? $50 is $50...
Picture of the carnage (so far anyway)
Hopefully the new chain will be in today.
application, belt, c5r, chain, double, installing, ls1, ls2, mississippi, replace, replacement, roller, timing, tuners, turbo
