Head Gasket and heads bolts for 04 ls1/ls6?
Old 09-16-2009, 02:41 PM
eric1h's Avatar
Default Head Gasket and heads bolts for 04 ls1/ls6?
I have a motor from a 2004 vette(ls6 block) with 241 heads
I need to pull the heads, what head bolts and what size head gasket do i need?
I see all kinds of info on short bolts, long bolts for a 2004, how do i know which?
the pistons are -2cc dished pistons, should I stay with a stock size HG? .050?
Thanks in Advance
Old 09-16-2009, 02:59 PM
NemeSS's Avatar
u can reuse new gm bolts, if its a ls6 block, it wil have the long and short bolts, u can reuse new gm 5.7 gaskets as well
Old 09-16-2009, 03:10 PM
eric1h's Avatar
by reuse, you mean just reuse the one i pull off? I thought that was always a big no no
Old 09-16-2009, 03:17 PM
NemeSS's Avatar
no, i meant use same part number.
cannot reuse used gaskets or gm tty bolts.
