those who run low 7s 8th mile?
Old 09-17-2009, 06:55 PM
93306's Avatar
Default those who run low 7s 8th mile?
i have a 01 z28 with 3.73s and ported tb with airlid and a4 trans i wanna know a proven combo to do this on motor alone using stock heads my car has 128,000 miles
Old 09-18-2009, 01:36 PM
FiFdYnUtz's Avatar
a big stall (3600-4000), a fast 90, a nice sized cam (231+/ms3/polluter/trex), and a spot on tune...i would think...
Old 09-18-2009, 01:37 PM
FiFdYnUtz's Avatar
and my car runs mid 7's in the 1/8 and i have 128k on my stock shortblock as well...
Old 09-18-2009, 01:57 PM
Hamrdown's Avatar
As said above. Big stall, good cam, fast 90 or 92 intake and throttle body, you didn't mention any exhaust mods so definately long tube headers & true duals. Also suspension setup need to be top notch. Control arms, relocation brackets, torque arm, and for the track remove front swaybar to allow for better weight transfer. Last but not least slicks or et street drag radials. Or you can go with the boltons you have now with a good stall and exhaust and add a 100 shot of NO2 and be there a lot easier and cheaper. Just another option.
Old 09-18-2009, 02:11 PM
NSSANE02's Avatar
Stall, suspension, sticky tires, full exhaust, cam.
Old 09-18-2009, 02:16 PM
StreetSilverado's Avatar
My old set-up ran high 7.3's-low 7.4's all motor. 231/237 TSP cam, Stock LS6 heads, 1 3/4 Longtubes, 3" ORY through a magnaflow, and a LS6 intake, 3.73's on sticky tires.
Old 09-18-2009, 02:34 PM
02_camaroz28's Avatar
Do you know the casting numbers on the LS6 heads you ran?
Old 09-18-2009, 03:33 PM
Nitroused383's Avatar
243 is the casting number for LS6 heads.
Old 09-18-2009, 03:55 PM
MARKSZ71's Avatar
4000 stall,stickey tires,skinnys,and a good cam,
Old 09-18-2009, 04:18 PM
^^6What he said. I also had a litte 3600 stall with a 1.69STR and still ran those times
Old 09-18-2009, 04:22 PM
FiFdYnUtz's Avatar
yeah i think once i put a good gear in my car i will be in streetsilverado's range because our mods are almost identical...plus i have a pretty conservative tune on the car now..
Old 09-18-2009, 06:52 PM
93306's Avatar
thanks for the info guys im planning on a 3600 converter and long tubes and i have really been stuck on the cam choice i had a friend with all that and the best his ever ran on motor was like a 7.80s with heads and ive seen one with cam only go a 7.30 with a 3600 converter and 3.73s .... my main goal is to drive to the track run 7.30s or quicker with stock heads and bottom end n/a just to prove a point to some guys cause i know it can be done once i get it in that range it will be getting sprayed 150-175
Old 09-18-2009, 06:56 PM
NSSANE02's Avatar
Do you want to keep it at stock weight?
Old 09-18-2009, 07:16 PM
5_02ls1's Avatar
in a full weight car your gonna need alot of weight pulled over 400rwhp a rreally good dialed in suspension....beefed up rearend of some sort and alot of verter....and the main mod....seat time.....also add in some nice air and track prep.....
look at the stock internal and cam only list in drag racing results.....theres alot more to it than asking what setup to run....
if i had to pick a setup id say
rearend either put axles in yours or get a 12 bolt
built tranny with a 4000-4200 stall
remove anything from the car it doesnt need to go fast
ported 90/90 setup
cqmshaft???????????custom maybe????
long tubes true duals dumped
all the other bolt ons
and a nice dialed in suspension...
seat time
blah blah blah blah....
good luck
Old 09-18-2009, 07:19 PM
jetlag's Avatar
Bolt-ons and a small dry kit.
Edit: Nevermind, just saw where you said on motor only.
Old 09-18-2009, 07:23 PM
98z-28redcamaro's Avatar
seen a guy run 7.70 w tires, tune and stall... put some gas on it and you will be in the low 7's
Old 09-18-2009, 07:45 PM
5_02ls1's Avatar
damn that must have been som serious-DA....usualy takes full bolt ons a stall and some good air to run 7.70s
NSSANE02's Avatar
If you get all the suff thats been listed and you pick a healthy cam you won't need much if any weight taken off. Then again if you are willing to take a bunch of weight out you may not even need the cam. Or do both...
Old 09-18-2009, 07:46 PM
93306's Avatar
thanks guys and trust me if i dont think it needs it it will come off and i know where a deal is on some suspension adj ta lowers and pan hard bar... the sway bar is coming off as soon as i can get it on the lift along with other misc. peices lol
Old 09-18-2009, 07:49 PM
93306's Avatar
i really get into the weight reduction thing but try to make things look as stock as possible
Quick Reply: those who run low 7s 8th mile?
