ls6 heads and shaft mount rocker arms
will the yella terra or the jesels bolt on a set of stock ls6 heads where they have the longer valves. probably a dumb ?
I can shift faster than you.
The Yella Terras bolt on just fine. You may need to machine the pushrod holes for the Jesels though. I have never used them, so someone else may chime in with some first hand experience.
