comments on my soon to come set up...
Old 09-17-2009, 08:52 PM
rggbly's Avatar
Default comments on my soon to come set up...
i've been reading around a lot lookin at as many h/c setups as possible and comparing dyno sheets and off the shelf camshafts with customs ones and everything else. i've also talked to some knowlegable guys at the track who are DAMN succeful with they're setups. i talked to tsp and got a better idea of what to look for so basically here's what im workin with. stock bottom end(for now)lookin to spray 150-200 on a two stage set up so i need a cam that'll like nitrous. i have 4.10's in my nine inch and i like them so a cam with a little more duration would be benefitial to me. i'm six speed so stall doesn't matter. i dd the car so it's gotta be somewhat tame. I don't feel a need to go custom because i feel the tsp 233/239 with a .595/.603 is perfect and will match up quite nicely to a set of PRC stage 2.5 heads. it's got the xer lobes which i've heard a lot of good **** about. i've heard the cam idle even with the 112 lsa and it sounds way smaller then it is which is another plus. I haven't decieded on the lsa yet (choices are 112,13, and 14). so what do you guys think? please only experienced members. thanks fellas
Old 09-18-2009, 07:52 AM
Chrome355z's Avatar
I'm running a similar cam. G5x2 (232/240) on a 112 and love it. I think you'd be happy with the 112+4 on that cam.
Old 09-18-2009, 09:36 AM
TooLateVTEC's Avatar
I vote 112.
Old 09-19-2009, 11:44 AM
rggbly's Avatar
well i think the 112 would do better on motor but would i benifit from going to a 113 or even 114 for nitrous? and can some one explaine the lsa+a few degrees? thats the only thing i don't understand about cams. thanks
Old 09-20-2009, 01:07 AM
TransAmcoupe98's Avatar
the "+" dictates the advance that is ground into the cam. For instance, a cam that is on a 108 ICL with a 112+2 LSA indicated that it has 6 degrees of advance.
Old 09-20-2009, 12:16 PM
rggbly's Avatar
anyone got any other comments about my set up? suggestions?
Old 09-20-2009, 03:37 PM
blue99fbody's Avatar
i think a ms3 would suit u nicely thats what im running, on a 113lsa spraying 200 and have went 10.67@130 on stock 853s. very drivable too, i love it. im a m6 also
Old 09-20-2009, 05:11 PM
rggbly's Avatar
ms3 is a good bit bigger. i think the 233/239 will be a little more street friendly plus tsp says the power band is lower which is more convenient
Old 09-20-2009, 05:54 PM
vsocks1's Avatar
I believe 112+2 has 2 degrees of advance ground in....
