How fast have you been or seen a 224/228 cam go?
That's the cam I just put in my vette last week. It pulls like hell now! It made 397/384 on what I was told a conservative dyno. Should be in the 11s no problem now so with that weight, probably low 12s?
I'm running a 224 w/581 lift and 1.8 rockers and 3500 lbs plus driver (still has jack and spare tire). So far it went 7.36 in 1/8 th. It's a comp. Cams custom grind from texas speed. I've been to track twice and had bad trans and converter first time and didn't have time to get shift points worked out before second trip. I think she'll get into the twentys at least. It's still pretty smooth idle.
Why don't you look into the Lunati VooDoo line like what I got, I know for a fact you'll see low 11's maybe even high 10's on your auto and I have there second to smallest cam and you've seen what my car does....lol
And plus you have enough of stall for a bigger cam.
One reason is the Comp Magnum 1.85's I am running. I like them and want to keep them. The other is I like the red light to red light torque and not having to spin it 6500 plus to make power. Third is just my fat car so I need a torque cam rather than just higher HP numbers. The cam I have will give me .581/.583 lift with my rockers and it's here.
