Cam Application?
Cam Application?
I've got new cam I took out of a GM 2001 Corvette crate motor. It was a 350hp/385 ft# torque. Specs are
218 intake
204 exaust
551 lift intake
555 lift exaust
on a 117
Would this be a good upgrade for a stock 5.3 motor and what would be a fair price for it? I got the specs fron SDPC so they ought to be right.
218 intake
204 exaust
551 lift intake
555 lift exaust
on a 117
218 intake
204 exaust
551 lift intake
555 lift exaust
on a 117
218 intake
204 exaust
551 lift intake
555 lift exaust
on a 117
This would be considered an upgrade to the 5.3, but there are other options out there that would be better. Doing a cam change is a lot of work and should be worth doing. Also, the Z06 cam has a smaller base circle compared to stock cams. You might need longer push rods to compensate. the LS6 motor used longer valves to make up the difference.
the numbers r backwards... its a 204/218, .551/.547, 117.5lsa... and its not a 2001, its a 2002+ LS6 cam... unless it DID come out of a 2001 LS1 motor, then those numbers aren't even close... its more like 197/207, .46x/.47x, 116lsa... the stock 5.3 cam is like 190, .46x, 114lsa... the ls1 cam will move the power way up high in the rpms, where u won't use it, especially if its in a heavy truck...
It was listed as a GM Factory 2001 Corvette crate motor and it came with both the Fbody and the vette oilpans. I know for a fact that it had 241 heads on it so that rules out the Z06. I bought it still in the original crate from Mizfitsmotorsports who was a sponcer at that time.Its a mystery!!! Maybe SPDC will chime in.
