Recommend me a cam
Recommend me a cam
So I've got a a 2002 Z28 M6 with K&N FPIK, full exhaust, ported throttle body, and full exhaust. I plan on also getting new heads and intake but I have no idea which ones or when that will happen. I've been considering the MS3, Torquer V2, and the Texas Speed 233/239 cam. I want something thats going to make good power but not be too extreme.
i would remove the MS3 from that list.
the Tv2 is a good cam, my Tv1 is very easy to drive on the street, other than the clutch being touchy (stg 4 w/ alum flywheel). i can cruise around town at 1200-1500rpm no problem.
and having <.600" lift will increase your options for heads that won't require flycutting.
that cam, with something like some stg2.5 5.3L heads and a ported FAST would yield 450rwhp.
my Tv1 made whats in the sig on stock heads and a stingy dyno.
LS1Tech Premium Sponsor
Checkout the V3 if you have the spring for the extra lift. It's without a doubt better across the entire useable rpm! We also have a new 229/234 camshaft that's working very well for us! I'd personally go Torquer 3 without a doubt!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
would you have to flycut with the tv3?
Like the guy above stated, you will NOT need to flycut with a stock long-block.
__________________
