ARP head studs torque specs?
Old 09-25-2009, 11:32 AM
Mean Green z28's Avatar
Default ARP head studs torque specs?
I've searched and come up short...
I have 234-4110 ARP studs on my 6.0ltr iron block. Worked fine until I blew a gasket, now I wanna make sure I put it back together right. I've long lost the box they came in, so short of calling ARP and bugging them about it, this is the best option. What are you guys torquing them down to?
The only specs I can find on their website is 90ft-lbs with 30wt. and 63ft-lbs. with ARP moly for the 11mm studs. There's other numbers for higher tensile strength studs, but this was the minimum numbers I copied from their catalog page 24 (http://www.arp-bolts.com/Catalog/Catalog.html) ... input?
Old 09-25-2009, 02:04 PM
niceguyyy01's Avatar
subscribing
Old 09-25-2009, 04:28 PM
SilverSS's Avatar
I just bought another set. This time it says 80ft-lb with ARP lube. 85ft-lb with motor oil. Up 10ft-lb from my last set.
Old 09-25-2009, 06:10 PM
vettenuts's Avatar
I don't have my ARP part number with me but those were the numbers I used and they were provided by ARP. My original instructions were 70 lb-ft. 22 lb-ft on the small ones as I remember.
Old 09-26-2009, 08:57 PM
up! Was hoping to see more clarification into this...
Old 09-30-2009, 08:59 AM
I guess more people get work done than work on cars themselves ...
thought a simple question like this would get more answers/unput
Old 01-11-2010, 01:16 PM
Banned Village Idiot
LS1BLKSS's Avatar
bump! gonna install the studs in a few need same info
Old 01-11-2010, 01:26 PM
vettenuts's Avatar
Those are the numbers straight from ARP. Why not just call them.
Old 01-11-2010, 05:28 PM
JPH
JPH's Avatar
Both 11/8mm studs in finger tight, then torque nuts to 35/65/85ft. lbs on 11mm nuts and 10/20/30ft. lbs on 8mm nuts with SAE30 motor oil! (chamfer side of washer down towards head also)
Old 01-11-2010, 07:33 PM
vettenuts's Avatar
I thought the chamfer was up.
Old 01-11-2010, 09:05 PM
BowtieBoyAV's Avatar
I dont have ARP studs, but I know on the ARP bolts the chamfer side is up. It is there to match/mirror the small radius on the underside of the bolt's head.
Old 01-12-2010, 01:35 AM
KILLER-LS1's Avatar
I would highly recommend using ARP's Ultra torque lube. its like 5 bucks and will get you a much more accurate torque reading.
With ARP Ultra torque 80 lb/ft on the larger studs, 22 lb/ft on the smaller studs
From ARP's FAQ section
"1. Does the chamfer on the washer go up or down?
The chamfered side of the washer goes up toward the head of the bolt."
Old 01-12-2010, 01:38 AM
KILLER-LS1's Avatar
1. The friction factor changes from one application to the next. That is, the friction is at its highest value when the fastener is first tightened. Each additional time the fastener is torqued and loosened, this value gets smaller. Eventually the friction levels out and becomes constant for all following repetitions. Therefore, new fasteners should be tightened and loosened through several cycles before applying final torque. The number of times depends on the lubricant. For all situations where ARP lubricants are used, five cycles are required before final torquing.
Old 01-12-2010, 10:24 AM
JPH
JPH's Avatar
Up on a bolt, down for a stud the way i do it. Just look at the surface area of washer with the chamfer in it, and then flip it over and look at the other side? Then tell me which side you want the nut pushing down against?
Old 01-12-2010, 10:47 AM
KILLER-LS1's Avatar
Up on a bolt, down for a stud.
Not true, chamfer ALWAYS faces toward head of bolt/nut
see my post https://ls1tech.com/forums/generation-iii-internal-engine/1226761-how-properly-install-torque-arp-fasteners.html
Old 01-12-2010, 10:50 AM
JPH
JPH's Avatar
Originally Posted by KILLER-LS1
Reread my post again. The chamfer side is designed for a bolt, it has no purpose for a stud. But good write up though.
Old 01-12-2010, 05:20 PM
SilverSS's Avatar
I'm with you on that. All the chamfer side did for me was put a nice ring notch indention on the nut and less contact area. I'm going chamfer down from now on.
Quick Reply: ARP head studs torque specs?
