ls6 cam or go bigger
Old 09-25-2009, 05:08 PM
mknight759's Avatar
Default ls6 cam or go bigger
this is the camshaft I am using I have a stock bottom end and a set of stock 243's for my heads i have the engine apart and was curious if anybody thought it would be worth it to go ahead and put a bigger cam in i know this one is bigger than the stock one inthe the f-body cars lts also an auto by the way Camshaft, Hydraulic Roller Tappet, Duration at .050 in. 204/218, Lift .550/.550, Chevy, LS1/LS6, Each
Old 09-25-2009, 05:18 PM
ramdaspadhye's Avatar
What are you wanting out of the motor? daily driver? weekender? Leaving everything stock or what? If you go with a cam, you'll need to replace your valve springs. What RPM range will you be seeing most of the time? What gears? Lotta questions need to be answered before swapping a cam. You gonna put in a higher stall?
Old 09-25-2009, 05:19 PM
S1LV3R's Avatar
Keep in mind if you go bigger, you'll need a stall as well as the correct springs and tune to go with the cam.
It all depends on what your plans are for the car.
Old 09-25-2009, 05:20 PM
S1LV3R's Avatar
Ha ha, you beat me to it!
Old 09-25-2009, 08:24 PM
mknight759's Avatar
its in my s10 gonna drive it everyday probably seeing more of the lower rpm's exept when my foots in it gonna change gears to 373 26.5 in tire I don't know much about cams so looking for any help is what i have a good combo
Old 09-25-2009, 09:28 PM
NemeSS's Avatar
if anything your engine will be around 405bhp minimum with that cam and those heads, assuming u got ls6 intake as well, it will net more if u have hi flow exhaust, tune, and other supporting bolt ons.
Old 09-25-2009, 11:46 PM
transamfreak01's Avatar
imo i think that the ls6 cam is pointless to put in. i just think that if youre going to take the time and spend the money you should get a little more out of it. and i would definitly get a converter. it is honestly the best mod i have done. if youre looking for a smaller cam get something like a 224. i have a 226 and it drives great. i take my car out for an hour or 2 at a time and have no problems
Old 09-26-2009, 03:07 AM
tr224 on 112 and a 2500-3000 stall in that light lil truck should do just fine.
Old 09-26-2009, 07:27 AM
mknight759's Avatar
what about this one with a 2500 stall on 112 lsa and how much hp do you think i could expect from a cam change the engine should already be a little over 400
The Texas Speed 224/224 .581/.581 Camshaft With Your Choice of Lobe Seperation.
Old 09-26-2009, 11:36 AM
SOMbitch's Avatar
If you are gonna stall it that cam would be great but then why stop there I would go bigger.
But.... What is budget? Stall $600+, cooler $60, cam $389, springs $150-$250+, pushrods $100, tune $450+......
or used LS6 cam $100, new springs $60 and I would do pushrods too another $100
Or the middle ground..... Do something like a 220/220 wth springs and PR's and run the stock convertor. I wouldn't recommend going bigger than 220/220 on a stock convertor though some on here do. I would still figure a tune in with this route....
Old 09-26-2009, 12:16 PM
mknight759's Avatar
well i already have a brand new ls6 cam and yellow springs just can't deciede wether to use them or go a little bigger
Old 09-26-2009, 12:36 PM
eseibel67's Avatar
If you want to keep the low end torque, the LS6 has it in spades.
Personally however, I would go bigger. LS1 engine still has great manners down low if you go with an afermarket cam with more duration. With lots more up top.
Old 09-26-2009, 02:20 PM
WSsick's Avatar
AT THE MINIMUM, something along the lines of the TSP 228R. its by no means a big cam so it will drive, idle, and tune just fine while making a good amount of power, 390+ with all supporting mods. the ls6 cam really isnt worth it. some people like 224's, but for just a little more duration at no cost of driveability, etc. you will gain more.
Old 09-26-2009, 03:18 PM
Johnnystock's Avatar
Do it once, do it right. Go bigger now or later.. I think you need to be closer to something at least 224-228 to get something that will put a smile to your face.
Old 09-26-2009, 03:29 PM
98TADRIVER's Avatar
definately go bigger! you will not regret it!!
Old 09-26-2009, 04:35 PM
mknight759's Avatar
well do you think it would be worth going to this one i am going to drive it everyday
Old 09-26-2009, 07:18 PM
I would go with 228.. but 224 is a proven and nice DD.
Old 09-26-2009, 09:05 PM
T-Pat's Avatar
So if i'm understanding this right, if I were to put an LS6 cam in my LS1 I would have to change my srpings as well correct? I didn't know if those springs would hold up or not,
Old 09-26-2009, 09:30 PM
SOMbitch's Avatar
Yes the $60 LS6 springs. Go back and reread my post. It all depends on what you want to spend.....
Old 09-27-2009, 02:27 PM
JPH
JPH's Avatar
Ya, use something in the mid 220 range imo. 224/232 or 228/232 etc...
Quick Reply: ls6 cam or go bigger
