Which Heads - PRC LS6 or 5.3L?
Old 09-26-2009, 10:48 PM
sspower23's Avatar
Default Which Heads - PRC LS6 or 5.3L?
2001 camaro SS, LS1 motor, 6 speed, LS6 intake, 228 cam .585 lift 112 lsa, LT headers, ORY-pipe. Maybe getting a FAST 92/92.
Which heads will give Me the most RWHP gain, PRC (LS6 or 5.3L) stage 2.5 ported Heads?
Thanks
Old 09-26-2009, 10:52 PM
LsxCody's Avatar
I ran the prc 5.3 heads on my truck and liked them but IMO I'd do the ls6 heads
Old 09-26-2009, 11:00 PM
TURBO6.0L's Avatar
The LS6 heads should flow just a little bit more. A few cfm's different is all.
Old 09-27-2009, 08:21 AM
PREDATOR-Z's Avatar
If done properly, at correct chamber size (all being equal), the 243s will win.
Old 10-01-2009, 06:00 PM
gnasty1521's Avatar
I was under the impression that the boost in compression would create more power (as long as they flowed the same). I vote for the 5.3s, it is a proven setup on the forum.
Old 10-01-2009, 06:51 PM
SIC GTO's Avatar
damn I wanna know the same thing.
I'll be running the ms3?
Old 10-01-2009, 07:37 PM
TURBO6.0L's Avatar
You could mill the LS6 heads some if you want more compression.
Old 10-02-2009, 04:33 AM
PRE-Z06's Avatar
true, but doesn't milling hurt actual airflow, possibly countering the slightly higher cfm readings of the ls6 heads?
Old 10-02-2009, 09:07 AM
PREDATOR-Z's Avatar
not if you mill .030 or less, above that you start registering a slight decrease.
Old 10-02-2009, 09:22 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Like stated, the LS6 heads will make more and better power than the 5.3L heads when setup properly. The 5.3L heads are very popular, due to their price however! We can mill the LS6 heads a bit to bump your compression up, without sacrificing your piston to valve clearance on a stock short-block for no extra charge when you purchase them new!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 10-02-2009, 11:06 AM
gnasty1521's Avatar
Ah ha! Put me in my place good. Well it's always great to learn something new.
Old 10-02-2009, 11:16 AM
The LS6's offer better flow, even after porting, than the 5.3L heads.
__________________
Old 10-02-2009, 11:20 AM
Jason 98 TA's Avatar
Don't forget the PRC 215 heads as well! If you use your spring kit you'll get a aftermarket casting head with smaller runners, your choice of chamber size, better p/v, etc for under $2000!!!
http://www.texas-speed.com/shop/item...d=993&catid=20
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
