Shaving LS1 heads
Old 09-28-2009, 06:37 PM
357i's Avatar
Default Shaving LS1 heads
I read the info in the stickys above and read some info on cc's and c/r. I see SLP offers pushrods that are .025" shorter than stock, I was thinking about getting them and having the stock LS1 heads cut down .025" Will it be worth it? Will I have any intake fitment issues?
thanks guys
Old 09-28-2009, 09:27 PM
LSX Mechanic
Damian's Avatar
.025 won't cause any intake fitment issues, but it could cause some piston/valve clearance issues depending on what size cam you're running. I'd stay below 230 degrees of duration and 108ICL or above on your camshaft selection.
Old 09-28-2009, 09:50 PM
02*C5's Avatar
I ran a 232/238 600/600 109LSA with my 241 heads milled .030, 59CC chambers and over sized valves. Ran the LS7 lifters and comp 7.325 rods. you'll be fine. I did end up switching over to 243 heads. Me you I'd save some money and get the 243s. Get TEA or Total Flow Induction CHD to do your work for them if you supply the parts (ie springs, valves, retainers) and such you'll save a hell of a lot of money.
Quick Reply: Shaving LS1 heads
