Rocker Arm Trunion upgrade kit
Old 10-01-2009, 12:26 AM
Mean Green z28's Avatar
Default Rocker Arm Trunion upgrade kit
http://blogs.corvettefever.com/65629...ade/index.html
http://www.summitracing.com/parts/CCA-13702-KIT/
Anyone tried these? Seems to be the same thing done by Harland Sharp?
Old 10-01-2009, 02:34 AM
Hamrdown's Avatar
Yes I have them. They work great, excellent quality, and a heck of a lot cheaper than harland sharp. They don't come with instructions though. You have get the instructions off of Comp Cam's web site. It's real easy to do if you have a press or vice. Takes a couple hours if your very meticulous and careful. They are fully enclosed and use snap rings to hold them in place. I ordered mine from Thunder Racing. I think I paid around $135. I highly recommend them!
Old 10-01-2009, 01:21 PM
thanks man, def. what I wanted to hear. Just need to make sure I can spare the $'s right now. I have a full machine shop and machinists at my work at my disposal so it shouldn't be an issue getting them installed. The only thing that I'm worried about is if it'll have the same failures as HS had with an early build of their units before they upgraded the bearings and now seem to have to run an additive in the oil to cure the issue.
Old 10-01-2009, 02:16 PM
vipvegas's Avatar
Get them I love them.. Plus you cant beat the security for the price.
Old 10-02-2009, 01:22 PM
02SOMWS6's Avatar
good info . I have 2 builds going on and 1 will have H.S rockers and the other will have factory upgraded rockers. Can't wait to see the diff. between the 2 in weight
Old 10-02-2009, 01:26 PM
LargeOrangeFont's Avatar
Thanks, I didnt know about these! I was going to send mine in to Harland Sharp.
Old 10-03-2009, 11:49 AM
Hamrdown's Avatar
Glad to help
