what rod length do i order for stock LQ4 block?
Old 10-01-2009, 04:33 PM
TurboZ28408's Avatar
Default what rod length do i order for stock LQ4 block?
im looking to have a lq4 iron 6.0 liter block built for boost. what rod lengths do i need ? i see on center, off center 6.100 long 6.125 long
this is going to be a stock stroke/crank block with wiseco pistons.
thanks !!!
Old 10-01-2009, 04:39 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Which Wiseco part number will you be running? That will tell the story as to which length you need. Most of the Wiseco's are setup to be a good bit in the hole with the stock or 6.100" rods whereas the 6.125" will be about zero deck at 9.235-9.24".
Let us know which number you're going to run and we can get you set up with a rod that will work for you
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 10-01-2009, 07:44 PM
k392A3
Old 10-02-2009, 09:28 AM
I believe those had he same compression distance of 1.304" like the new K392X piston does. With a 6.125" rod, your piston will be zero deck at 9.24" (typically that puts you .005-.010" out of the hole on an iron 6.0L block). The 6.100" rod would have you zero deck at 9.213" (way in the hole on your block, unless you deck it quite a bit).
We've got some great deals on 6.125" rods. Let us know if we can help!
__________________
Old 10-02-2009, 09:58 AM
for a boosted application which rod would you get ?
Old 10-02-2009, 10:39 AM
Even on boosted applications, I'd prefer not to have the piston in the hole .020-.025"...so I'd go 6.125!
__________________
Old 10-02-2009, 10:48 AM
if it sticks out of the hole woudlnt it hit the head ?
and the rods you're thinking of are CRS6125B3D ??
Old 10-02-2009, 10:55 AM
No, even the stock LS pistons, for the most part, are out of the hole .005-.010". The same goes for many aftermarket pistons too.
__________________
Old 10-05-2009, 04:18 PM
ok so those pistons, 6.125 rods. if i get a 4" eagle crank itll be a 408 stroker right ?
Old 10-05-2009, 04:36 PM
You can't run those pistons with a 4" stroke crankshaft! It is setup specifically for the stock (3.622") stroke crank. If you tried it, your pistons would be out of the hole close to .080"!
__________________
Old 10-05-2009, 07:29 PM
stevied916's Avatar
what about if the block is decked? would it be better to use the 6.100 rods?
Old 10-06-2009, 09:16 AM
No good. Even with a 6.100" rod and 4" crank, you'd be out of the hole .164" with a 9.24" deck height. Wiseco does make great pistons for the 4" stroke combos though!
__________________
Quick Reply: what rod length do i order for stock LQ4 block?
