cooling ?'s disconnecting heater core feed/return..
I seen on Horsepower Store's car where the heater core is removed from the side of the water pump. Is there anything wrong with doing so? I am wanting to move the heater core feed and return from the side of the water pump(block off the pump) to somewhere else where the heater would still work. I was thinking that maybe I could get a feed frrom the back plug on the passenger head, then return it into the return to the radiator. Can it be done? Whats your opinion? I am moving it to build a passenger side turbo manifold, thanks.
