Whic cam swap gasket kit has everything?
Old 10-03-2009, 10:15 PM
blubyu02's Avatar
Default Whic cam swap gasket kit has everything?
I've got everything for camswap except bolt/gasket kit whoseells the kit with everything? TSP has it 4 54 bucks everywhere else i 77-83 why is tsp much cheaper
Old 10-03-2009, 10:18 PM
SuperSlow02's Avatar
TSP's has everything...which really isnt much lol, 2 water pump gaskets, 1 timing chain gasket, and a crank bolt. But it has all you need for a cam swap and if its the cheapest...bingo
Old 10-03-2009, 11:13 PM
blubyu02's Avatar
whw about valve cover gaskets? and whats tha difference in the gm crank bolt and the arp one?
Old 10-03-2009, 11:29 PM
valve cover gaskets are rubber, and they are attached to your vavle covers, so no need for new ones, and the arp would be stronger...i guess. But the factory one works just fine.
Old 10-03-2009, 11:47 PM
blubyu02's Avatar
hey i appreciate it man thanks 4 da info
Old 10-04-2009, 01:27 AM
not a problem, have fun with the swap
Old 10-04-2009, 10:14 AM
garygnu65's Avatar
the gm bolts is a stretch to yield bolt ,you do not reuse!the arp can be reused.
Old 10-05-2009, 03:01 PM
LTHL VNM's Avatar
give us a call up at the shop, we can get you everything you'll need for the swap
Old 10-06-2009, 09:22 AM
blubyu02's Avatar
I got everything thanks thunder racing
