progressively been getting richer... help
Old 10-07-2009, 06:45 PM
tribaltalon's Avatar
Default progressively been getting richer... help
cant figure it out. its a 98 ls1 with a big cam, tune from hpe a couple years ago. i noticed it seemed rich a couple months ago and now its really rich at idle, smells like fuel real strong. no codes, etc. its bogging pretty bad as well. idles right where it always has. cant figure it out. sparkplugs would throw a code wouldnt it? it also will backfire a little on decel from WOT. car feels gutless, and i want a little affirmation on sparkplugs before i go through that headache. what plugs should i go with seeing as i do also spray 150 shot wet from time to time. Stock injectors btw. thanks!!!
Old 10-07-2009, 06:54 PM
ChucksZ06's Avatar
Depending on the tune, the maf and o2 sensors can be changing the original a/f to what the sensors "think" the engine wants in the way of a/f ratio.
SOMbitch's Avatar
NGK TR6 gapped .038-.040
Old 10-07-2009, 07:04 PM
hmm. it has a granatelli maf on it, o2's are pretty new. o2's would pull a code wouldnt it? i wish the damn car would pull a code so i'd have some freaking idea. i'll be pissed if i sweat and swear over changing the plugs and it doesnt do anything (or fouls the plugs out again)
Old 10-07-2009, 08:56 PM
eallanboggs's Avatar
What are your LTFTs and STFTs? If your performance is down, but you don't have any DTCs have you don't basic old school tests(vacuum at idle and 2500RPM and a snap throttle, compression and leakdown). Once you have those things verified you can dig deeper.
Old 10-07-2009, 10:43 PM
compression is good on all cylinders. it doesnt lose a drop of oil over 5k miles (mobil1 syn) vaccum check is a good idea, what should it be pulling at the different levels? i'll check tomorrow.
it feels more like a fuel/spark issue then an actual motor issue. sometimes it'll pull hard like it should and other times (especially when its humid) it's super sluggish and really struggles until about 3-3.5k and then it pulls, but still not as hard.
Old 10-07-2009, 10:50 PM
lemons12's Avatar
Read the thread title and first thought in my head was, "Since when is getting rich a bad thing and why would he need our help to hinder this great thing that I wish was happening to me."
Didn't even read one word in this thread, so I'm no help.. Just thought I would share.
Old 10-07-2009, 11:09 PM
Paint_It_Black's Avatar
First thought was start looking at your injectors. I'd really like to see a picture of each spark plug though.
Old 10-08-2009, 12:26 AM
lemons12's Avatar
Went back and read...
I would say O2s.. Is it loading up in the lower RPMS? 1500-3500?
Old 10-08-2009, 01:25 AM
Schantin's Avatar
Well, I read the words "big cam" + "stock injectors". My guess is that your injectors are too small. Injectors should run at no more than 80% duty cycle WOT. On a fat cam it's easy to peg the injector duty cycle over 100%.
This lack of fuel is noted by the PCM and it "adds" to the LTFT (Long Term Fuel Trim) tables to compensate. For example, an inadequate injector might trigger an addition of 10% or more to the LTFT to compensate. NOW, when you go WOT, the O2 sensors are ignored and the computer calculates fueling based on the PE table (enrichment table) + the LTFT's at the time you stomped on the gas.
SO..... if the PCM is adding fuel all the time (say 10%) for small injectors when cruising through town, it will ADD that 10% to the commanded air/fuel ratio when you go WOT. End result = running pig rich. That leads to the back-firing you are describing + loss of power.
Trust me. Been there/done that.
Old 10-08-2009, 03:13 AM
lemons12's Avatar
80% is what people strive for.. It is not easy to be there though is it?
Old 10-08-2009, 11:49 AM
injector theory is interesting.. but wouldnt that have manifested itself a couple years ago when the cam was installed? bigger injectors is on the honey to do list anyway. it does explain alot of the symptoms im having. i think ill just deal with it for another month or so, buy bigger injectors (dunno what size yet) ls6 intake, new plugs and get it retuned and see what happens.
Old 10-08-2009, 01:36 PM
NC98Z's Avatar
Hows your water temp guage looking? I had a bad sensor one time and it made the cpu think it was Winter(below 0) when it was 98 degrees outside and it was adding fuel. Your 98s Water temp sensor is like the corvettes 3 wires instead of 2 and the 98 has the non idiot gauge. Have you cleaned your MAF lately? A can of MAF cleaner isn't but about $5.00. Also pull out your air filter, especially if you have done the free air mod or have a bottom breathing ram air system and make sure you haven't sucked up a plastic bag or two in front of the radiator. It never hurts to reset your cpu either and let it relearn it's operating parameters again. I'm still on stock 98 injectors also. But I don't use the NOS.
Old 10-08-2009, 02:53 PM
how do you reset the cpu? just unplug the battery right? i have the k&n cold air intake that sits right on top, and its clean. ill try cleaning out the maf. water temp is good, no issue there. i wasnt too worried about the injectors originally, i spray wet so it gets enough fuel, and on motor is only about 400-ish to the wheels through the stock ls1 intake.. i plan to change out the injectors eventually anyway when i get a good set of heads and get up around 450-500 to the wheels.
Old 10-08-2009, 05:42 PM
Soul TKR's Avatar
my injectors are running at 73% DC... still smells rich as hell
