how much hp would i miss out on?
I have a 98 Trans am a4. I would like to to atleast get a cam and LS6 intake. Heads would be nice.i know whp depends on many factors.Such as what cam and other bolt ons. But how of a difference would stock 243's over stock 98 heads make. would it be a huge difference or just 15 hp or so?
i was thinking of getting a stall . The car wont be a DD. just something i drive here and there. i guess i ill look into the stall first. thanks for the info
the yanks run a little looser than the others.If it's not going to be a dd,then i would go with a yank. It maximizes the stall better.
I know a few that run the Yank as a dd. They like them.
is swapping the 241 heads with 243 heads simple? just unbolt the old, and rebolt the new? ona bolt on car it would proly yeild what, 15wph? thats nice if you can go pull em off a car int he junkyard
Usually it's the other way around...
My Yank SS3600 is a very tight converter, almost feels like stock. I let a friend of mine drive my car and he said his TCI 3000 was a lot looser than the Yank.
I have to agree with SOM here. Yanks SS line is known for their tightness around town. Rear gear selection can play a huge role in how loose or tight a converter feels. Vigs are generally known to be a tad on the loose side and tend to be under-rated on advertised stall speed. Both are great converters BTW.
