TSP 231 237 on 112 info please
Old 10-14-2009, 03:23 PM
JASON 77's Avatar
Default TSP 231 237 on 112 info please
Recently got a TSP231 237 cam in on trade for some stuff. i know it is an older cam profile, but what can u tell me bout it? is it more of a higher rpm cam or across curve? what did u make powerwise with this cam?
have a set of 5.3 heads that flowed out at 316@600. ls6 intake and the usual bolt on's. let me know what u can tell me bout this cam
Old 10-14-2009, 03:45 PM
TooLateVTEC's Avatar
I have a 230/236-112 (on Comp XE-R lobes) in my car which sounds similar to that cam. It pulls hard from around 3000 on up to the shift points at 6200/6300...would pull the 6500 no doubt.
I have no #'s for you but its very driveable around town.
Hope that helps some.
Old 10-14-2009, 03:47 PM
JASON 77's Avatar
also where is the link to FREE MODS
Old 10-14-2009, 06:42 PM
Heavy Metal's Avatar
I have a 231/237 cam in my car, I have stock ls1 heads with hardend pushrods, 918 springs, and titanium retainers. My car makes ok power; 390 RWHP I cant remember the peak RPM(I only have a cam and some bolt-ons). It is an old profile, It started the "my cam is just a tiny bit bigger than your cam" wars. It should work great with those heads too, I think you will see a slight bump in compression with the 5.3 heads. Do a search and there are proabobly a million more details.
Have a good one,
Aaron
Old 10-14-2009, 08:21 PM
billymz28's Avatar
It is a great cam makes good power. My car made 436 hp. It can be a little rough on the street but managable.
Old 10-16-2009, 07:49 AM
BADBOYZ28's Avatar
I have this cam and like you mentioned its a outdated but its worked great for me. I also have stock heads with all the bolt ons and some nitrous. I dynoed a while back ago didnt make alot of power IMO 373 rwhp if I remember correctly. That was with the verter UNlocked and a loose *** vig. 4000 and 3.73's. I shift at about 6800 rpm and it still making power. Hope this helps....
Old 10-21-2009, 05:17 PM
JASON 77's Avatar
any one else?
