What intake manafold for 454
Old 10-16-2009, 08:54 PM
red 454's Avatar
Default What intake manafold for 454
HI what intake manafold and TB would be the best for 454 stroked ls3 would the new fast 102 be big enough
thanks
Old 10-16-2009, 10:59 PM
Bader-X's Avatar
@@ 454 ls3? who sells this and for how much and what size pistin rod and crank?
sorry don`t know the answer but I think heads & cam specs and rpm and intended use are required to answer this
Old 10-17-2009, 12:41 AM
red 454's Avatar
ar ok i was refereing to a sleeved ls3 block BY red out to 454 or 454 lsx block from GM
just a good street engine nothing over the top med cam 6000 rpm max
thanks
Old 10-17-2009, 12:55 AM
LS6427's Avatar
If you're not going for big power, that FAST 102 ported is probably your best bet.
Old 10-17-2009, 07:05 AM
Bader-X's Avatar
then 102 or ported 102 if available shoud be plenty and what you`re looking for won`t max it with what you have in mind
