6.0 Intake question
Old 10-17-2009, 11:13 AM
madmike9396's Avatar
Default 6.0 Intake question
My friend recently just got a FREE 6.0 out of a truck and were are going to swap it into a toyota, I was wondering where i could find a carb and intake for it ? Thanks to anyone with info
Old 10-17-2009, 11:17 AM
livefast1's Avatar
man why can't i find deals like that lol. edelbrock makes carbed ls intakes as well as gmmp
Old 10-17-2009, 11:21 AM
sweet man thanks for the info
Old 10-17-2009, 11:27 AM
So will a ls1 and 6.0 parts interchange ?
Old 10-17-2009, 11:32 AM
OUTLWZ's Avatar
Yes the intakes will interchange.
Old 10-17-2009, 12:46 PM
Ok in the process of doing this swap will we need a computer to go with it all or can it be made like a regular sbc with distributor and regular coil ? Thanks to all with info
Old 10-17-2009, 02:36 PM
02*C5's Avatar
The carburetor package does not come with distributor, the distributor along with the balancer and a few other things are going to be bought apart. When you get the package make sure to ask all other supporting parts needed.
Old 10-17-2009, 02:54 PM
So a 6.0 can be made to run like a old school sbc Carb, regular coil and distributor with spark plug wires running to the spark plugs
Old 10-18-2009, 08:34 AM
Ph.D. in HUBRIS
custm2500's Avatar
Yes it can. Just so you know you free motor is going to become VERY costly! You would be better off getting a harness and computer. If you want the carb for looks or other reasons, awesome but plan on spending some cash. You will need to get the computer re-tuned because it is a for a 5.7 LS1 not a 6.0. Good luck.
Old 10-18-2009, 10:57 AM
thanks guys im not sure i thought going Carb would be easyer than trying to hook up all that fuel injection crap. Let me know your thoughts. which ever way would be easyest will be the way we go
Old 10-18-2009, 11:04 AM
hammertime's Avatar
Looks like there are two different schools of thought here
Distributor
Carburetor and Distributor make Big LS1 Power - Chevy High Performance
Coil on Plug
Forward Into the Past - Super Chevy
Personally, I would stick with the coil on plug, instead of adding the mechanically complex adapter for a distributor. To me, the mechanical distributor drive is another point for failure that GM has been able to eliminate on all the LS series engines.
Old 10-18-2009, 11:14 AM
livefast1's Avatar
is the edelbrock unit programmable or just the msd one?
Old 10-18-2009, 12:01 PM
the second pic looks cool but i would never figure out how to wire it all up.
Old 10-18-2009, 12:02 PM
I just like the clean look in the first pic with carb and distributor
Old 10-18-2009, 01:36 PM
hammertime's Avatar
According to the instructions, the Edelbrock unit has 6 different curves.
Wiring everything up doesn't look too bad, just one page on the instructions found here.
Here is the condensed version. The text from the link above has a great deal more description on how to locate and identify all the wiring. They couldn't make it much easier.
• TIMING CONTROL MODULE INSTALLATION:
1. Attach the module to the intake manifold so that the main harness will face towards the passenger side.
2. Route the harness around to the passenger side of the engine and towards the rear of the engine. Locate the Crankshaft Position Sensor
connector and connect it.
3. Locate the MAP Sensor connector and connect.
4. Locate the Camshaft Position Sensor connector and connect.
5. Connect the 7 wire connectors to each coil pack.
6. Locate the portion of the harness with the four non-terminated wires (Pink,
Blue, Black, & Yellow). These will be connected to the following sources:
Pink - Main power, connect to a SWITCHED ignition power source
Black - Chassis ground
Blue - A/C compressor
Yellow - Tachometer output signal
If you can handle that, but want a cleaner look, you can get a coil relocation kit and mount them on the firewall. Links to a couple of threads, and a pic from each one.
Coil relocation kit w/wires $155 delivered from CC Performance Parts
How many here keep the coils on valve cover
Old 10-20-2009, 03:10 PM
damn thats for the break down hammertime
Old 10-20-2009, 08:17 PM
ss454327's Avatar
Can he not get the computer and harness from the truck it came out of? I would definately keep the fuel injection if it were me.
Old 10-21-2009, 08:52 AM
Nah the truck that the motor came out of is going back together with a new 6.0
