Cam Question?
Old 10-19-2009, 01:57 PM
22blkmaro00's Avatar
Default Cam Question?
Can I use TSP's magic stick v4 cam with stock ls1 heads?
Old 10-19-2009, 02:24 PM
1SLwLS1's Avatar
I did, then I broke a rocker bolt and went to 799 heads
Old 10-19-2009, 02:27 PM
would 243 heads do?
Old 10-19-2009, 02:30 PM
1SLwLS1's Avatar
your 241s would work fine too, but ofcourse the 243s would be better
Old 10-19-2009, 02:39 PM
Well I was told you can't put a big cam in a Ls1 with stock heads and I wasn't sure of the truth of this
Old 10-19-2009, 02:41 PM
1SLwLS1's Avatar
you can, but you wont be making full use of it with the stock heads/LS1 intake
btw how do or did you like that cam?
Old 10-19-2009, 02:42 PM
well i plan of doing the lsx 92mm intake and tb set up as well
Old 10-19-2009, 02:44 PM
1SLwLS1's Avatar
I like it alot now that I can drive it again. I drove it for about 3 miles tuned and then the rocker bolt broke and thats all I got to drive it. Now with the 799 heads drive ability just needs some small tweaking from the tuner. The cam is super choppy/loud, but I was not really impressed power wise with cam only, we shall see with the heads/cam combo. I haven't gone WOT with the new heads and wont' until I get everything tweaked again, I am weird about it like that.
Old 10-19-2009, 02:56 PM
1SLwLS1's Avatar
shoot, you ought to be good to go then. If you're spending that much money, may as well get the 243s CNCed or something. I wouldn't recommend milling on those heads with stock pistons and that camshaft.
Old 10-19-2009, 03:06 PM
LS1-NAVY's Avatar
that cam was designed as a max effort cam for stock heads
Old 10-20-2009, 10:44 AM
I dont really want to change my heads but I dont wanna get it tuned and drive it and it break something right away on me either
Old 10-20-2009, 10:46 AM
Is your car an A4 or M6 and what kind of power did you make cam only?
Old 10-20-2009, 10:53 AM
1SLwLS1's Avatar
The threads for the rocker bolt were damaged, me changing heads was my fault, not in any which way shape or form, the large camshafts fault. I forced the bolt to go in there knowing the threads were already damaged. So you can definitely keep your stock heads.
M6, it made 391 through a Mustang Dyno and just recently with the 799/243 heads, it made 417 with a slipping clutch
Old 10-20-2009, 11:03 AM
O ok I see what your saying, well damn so the heads were deff worth it then? Did you have all your bolt ons when you put the cam only number down?
Old 10-22-2009, 12:42 PM
1SLwLS1's Avatar
the only difference b/w the two dyno numbers is the 799 heads. Same TB, intake, exhaust, etc. my bolt ons include MID length headers, ORY, Borla CB, stock pulleys, LS6 intake, Ported TB. hope this clears some confusion.
The heads were worth it. The heads cost me $350, but needed new gaskets and bolts and went ahead and did new lifters and shorter PRs, so it was roughly ~$850.00 for the new heads and what not. To some thats a tad expensive for stock heads, but I didn't have any more funds available to have the ported or anything. Nonetheless, that 850 add ~26 rwhp and ~10rwtq at 3500+ RPMs and no loss down low, so yea they were worth it.
