misfire
Old 10-20-2009, 12:36 AM
SMOKIN THE BANDIT's Avatar
Default misfire
ok so i have had this misfire on my 01 ss 6 speed for a while i had been lazy as into looking into the problem but the car is really running like crap and it keeps getting worst. it usually happens when i start hitting around 3500 rpm...i changed the plugs and wires , moved his coils around to see if it was one of the coils but nothing still getting a misfire what could it be??? also checked the fuel pressure and nothing it was good.. i am also getting another code it is to a secondary air injection smog pump ... i really need to get my car running so anyone ??? my next step is going to do a compression test and check my injectors
Old 10-20-2009, 09:44 PM
anyone
Old 10-20-2009, 09:50 PM
LS6427's Avatar
Which cylinder is misfiring?
Swap that injector to another cylinder, if thats not it then swap that spark plug....see if the misfire follows them. That will find the problem.
Also, if a spark plug wire is touching an exhaust pipe manifold at all...it will cause misfires in the mid-to high rpm ranges. Also, make sure the sprak plug wire(s) is snapped on good at both ends.
Old 10-20-2009, 10:10 PM
cylinder 6 is the problem and all the wires are good and plug and wires wre both placed correctly
Old 10-21-2009, 12:20 PM
bigboykilroy's Avatar
ok, swap cyl 6 plus and wire to 4 and 4 to 6, and coil if you want.
If it still is on NO 6 do the same for the injector.
You can also try a noid light on the 6 injector to see if its getting a signal to fire.
Old 10-21-2009, 03:03 PM
LS1PUNK's Avatar
Sounds like a bad injector, I had the same problem not to long ago. Replaced everything else leaving the injector as the problem.
Old 10-21-2009, 10:48 PM
cool i need to get some time off to check the injector out hopefully thats my problem
