12 O'clock & 12 O'clock...not DOT to DOT...cam install confirmation needed
Old 10-20-2009, 12:41 PM
LS1-450's Avatar
Default 12 O'clock & 12 O'clock...not DOT to DOT...cam install confirmation needed
I searched & replies were all over the place.
Please confirm that w/the #1 piston @ TDC on the COMPRESSION stroke, both the CAM DOT & the CRANK DOT are in the 12 O'clock postion. This is the correct orientation, cam to crank.
DOT to DOT ocurrs @ the bottom of the #1 piston stroke.
Old 10-20-2009, 02:05 PM
1CAMWNDR's Avatar
NO!!!
Cam gear dot in the 6 O'Clock position and crank gear dot in the 12 O'Clock position is dot-to-dot.
As in the dots are as close to each other as possible.
Old 10-20-2009, 02:09 PM
fast01's Avatar
For the love of God, don't crank that thing over!!!!
Old 10-20-2009, 02:17 PM
LS1-450's Avatar
Originally Posted by 1CAMWNDR
NO!!!
So, w/ #1 piston @ "TDC," Cam dot is 6 O'clock & crank gear @ 12 O'clock. OK, got it, thanks for the reply. I appreciate the help.
Old 10-20-2009, 02:33 PM
01ssreda4's Avatar
Yes. You were at TDC on the exhaust stroke. Its 6 o clock cam and 12 o clock crank just like stated for TDC on compression stroke.
Old 10-20-2009, 02:51 PM
LS1-450's Avatar
Thanks again guys. Yah, I was 180* off. Am getting' all the accessories back on now. Can't wait to fire her up.
Old 10-20-2009, 02:57 PM
xRelapse13's Avatar
jeez if you had left it like that and fired it up it would have made some very interesting noises. None to your liking im sure.
Old 10-20-2009, 05:16 PM
Navy Blue 01 B4C's Avatar
With both the crank gear and cam gear dots at 12 o clock, the engine will start and run just fine.
Old 10-20-2009, 05:38 PM
LS1-450's Avatar
Well, without incodent anyway; like 4 cylinders on & 4 off & a bit out of balance. No interference though, as you have noted.
Old 10-20-2009, 07:28 PM
01ssreda4's Avatar
Thats exactly correct. The cam spins once for every 2 rotations of the crank, hence the reason why the cam gear is exactly twice as big. Every other rotation of the crank (when its on 12 o clock) the cam is at 12 o clock, and then the following rotation the cam comes back to 6 o clock as the crank comes back to 12 o clock.
Quick Reply: 12 O'clock & 12 O'clock...not DOT to DOT...cam install confirmation needed
