No spark...crank sensor??
Old 10-21-2009, 10:03 AM
wytry's Avatar
Default No spark...crank sensor??
Not getting any spark at any cylinder. Checked all fuses/relays, actually replaced the Ignition relay. Still no spark. Ran the trouble codes, nothing out of the ordinary (cam swap, removed emissions stuff so there are several codes thrown). I have been told by several people that the crank sensor would cause the no start condition. Is there a way to test it? Whether it returns a signal/resistance/some other method? I just don't want to spend 60$ on a hunch. Any help is greatly appreciated. Thanks!
Old 10-21-2009, 10:50 AM
bigboykilroy's Avatar
I you have HP tuners in the VCM scanner, under vcm controls, click the special box on the right side, at the bottom there is a button CASE Learn.
Did you install the CAM dot to dot?
usually a cam swap wont take out a crank sensor.
Old 10-21-2009, 12:00 PM
wytry's Avatar
Don't have any tuning software, car has been on the stock tune for nearly three months with absolutely no problems. Yes it was installed dot to dot. Car has randomly started and run a few times since it has been down, maybe four times in thirty or so tries, but has not for several weeks now. Thought maybe a short somewhere but all the wiring I can see has perfect insulation and is not contacting anything that would ground it. Can the crank sensor start to go bad, giving random starts, then finally totally take a ****?
Old 10-21-2009, 12:27 PM
any sensor can all of a sudden take a ****.
Old 10-21-2009, 01:31 PM
wytry's Avatar
Well of course they can, but what I asked was can they work and sometimes not work? Like start to lose their functioning capabilities, then completely stop working one day? Or do they just die. Because it randomly started several times, but hasn't for quite a while.
Old 10-21-2009, 01:43 PM
ND2RACE's Avatar
Easiest way to check a CKP sensor is to watch counts on a scan tool, also I'd check the wires running to it they run right by the headers. You'd be best to watch live data on a scan tool, or just throw a sensor at it.
Old 10-21-2009, 03:46 PM
omarrakeen's Avatar
yep cranck sensor...same thing happened to me once i was actually driving i stoped at the traffic and the car went off n never worked! checked everything n everything was fine changed plugs wires coils and again nothing! then we figured it out and my car is bone stock
Old 10-21-2009, 04:02 PM
wytry's Avatar
Thanks guys! Guess I might have to find a good scanner or just drop the fifty bucks
Old 10-21-2009, 04:04 PM
omarrakeen's Avatar
why dont u get a sensor from some junk yard n try... there was an engine which i took the sensor from,when it worked i jst put everything back on n it has been 3 years now lol...gd luck anyways
Old 10-21-2009, 08:29 PM
BAD2000TA's Avatar
I was having a problem with a terrible misfire. Thought it was the crank sensor. Bought a new one, but it wasn't the problem. So, I still have the original that worked fine. I'll sell to you for $20.00 if you want.
Quick Reply: No spark...crank sensor??
