LS1 rebuild kit
Old 10-21-2009, 08:50 PM
NeedaV8foundation's Avatar
Default LS1 rebuild kit
hey guys im looking for a rebuild kit for an ls1 (rings, gaskets, ect.) ive searched everywhere with no results.
Old 10-22-2009, 12:32 PM
bump anyone?
Old 10-25-2009, 09:30 AM
lsx440's Avatar
try sdpc 800-456-0211
Old 11-10-2009, 08:21 AM
mrmahone's Avatar
Check this out:
http://www.summitracing.com/parts/FEM-BK6081000/
Old 11-10-2009, 09:21 AM
Jon@Texas-Speed's Avatar
We can get you fixed up. We have everything from GM replacement gasket and bolts to aftermarket Cometics and ARP hardware. We can get you rings are bearings as well. Let me know what you are wanting and we'll get you fixed up!
Jon
Old 11-10-2009, 09:58 AM
99SSAGUI's Avatar
the kit that mrmahone listed from summit is a good kit, however I will go with one of our sponsors like Texas Speed since the pistons on that kit are standard bore. Unless you have a brand new block you will need to hone your cylinders and will require oversize bore pistons. I myself just purchase a 3.905 piston from JE but I think you can go with a 3.903 but I am not sure who makes them. it will also be good if you can tell us what you are building i.e. a stock rebuild or a performance rebuild? you can rebuild your engine using your stock rods and crank (you will need new rod bolts) and have a nice 347 cid block. any way you decide to go make sure you do your research so you don't end up wasting time and money.
Quick Reply: LS1 rebuild kit
