Paging Terry @ Patriot
Dude,
Sorry about the broken spring that SUCKS! Hope there is no serious damage!
What happened. Did one of the dual crane springs break? If not, what springs and what cam you running and with what lift.
Best of luck on a speedy fix-up!
It's the same dual springs a few other people had problem's with, the cam only has .561 lift and the shift point are at 6100 rpm's.
But, it broke on my way to work, WTF
The car is running really bad, but I didn't see anything metal on the dip stick.
I only found one broken spring on the pass side so far and it looks like a clean break.
I just need to get it fixed asap
Thanks, I tried e-mailing, calling, PM'd, this was my last choice
I'm hoping everything esle is alright the oil pressure is higher then normal, so I'm really hoping they're no pistion damage
Do you guys think the heads need to come off to check everything out
Thanks, but what if I replace all the spring and I find out I have a bent vavle, this is my only car and need to get it up and running yesterday
I guess I'll try doing a compression test after drill tomorrow, hopefullt the vavle/s are ok.
Originally Posted by MTI 427 C5 Roadster
Sounds like the dual revs to me but not sure!
that's my guess. i broke a rev with only 4k miles and on a 224 .563 cam.
great springs
See Drew, nothing to worry about!
This is what customer service is all about. Terry never asked you how it happened or what the circumstances were. This is why he is and will continue to be so successful in this business. We spend a lot of $$ on our cars and we want someone to stand behind what they sell.
Way to go Terry!!!!
Mike
Way to go Terry!!!!
Mike
Originally Posted by John02SS
Reason enough alone right there for me to spend my money with Terry when I buy heads in the future. That and the product ROCK!
Good luck getting it back together Drew!
WAY to GO TERRY and PATRIOT PERFORMANCE!!!!!
Originally Posted by TVWilkes
These are the old springs that are no longer used.Drew,I will be sending you a new set of valve springs monday,for free.Thanks, Terry
