427 stroker
427 stroker
any suggestions? What are advantages and disadvantages? What price am i looking at? Places to get the kit? Power output? Its gonna be bolted to a built 350 w/ manual valve body and a 12 bolt.
Lunati, Callies, and Eagle all make a 4" 4130 crank. Rods can be found from any of the companies. The pistons are made by diamond, je and ross. Lunati and eagle are offering complete stroker kits. Are you doing aluminum or iron block? Alluminum is the better deal with a resleeved block for reduced weight and less stroke than the iron block. The resleeved all block have had a lot of sleeve problems though with over heating and sleeves dropping. The iron block is great if you want to do a 409 with a dp nitrous system. Check out the lunati web site for all the different combos they have.
