Anyone have dyno numbers and or track times with MM2 cam 228/234?
Old 12-07-2003, 12:01 PM
Chicago Crew UnderBoss's Avatar
Default Anyone have dyno numbers and or track times with MM2 cam 228/234?
THis MM2 cam 228/234 607/598 110 + 2 is powering a texas A4 vette with stock cubes into the 10s consistently with just a CAM and bolt ons?
Anyone here also running that cam and if yes what dyno and track numbers you putting down?
Thanks
Old 12-07-2003, 12:04 PM
SPANKY LS1's Avatar
Originally Posted by MTI 427 C5 Roadster
100 + 2
I think its 110+2. 100+2 would be choppy, to say the least.
Old 12-07-2003, 12:25 PM
Oh me bad, yes 110 + 2. Was in a big rush as i didn't want to miss the first play of the Bears vs. Packers Game!!
GO BEARS!!!!!!!!!!
Old 12-07-2003, 02:37 PM
Sick_Silver_SS's Avatar
Try this website
www.bonestockracing.com
There are some local guys that run that cam on that site. I believe they have times/dynos under the garage.
Quite a few people down here are getting that cam from mmt. Sounds pretty wicked!!
hope this helps
Old 12-07-2003, 02:49 PM
LSX Mechanic
Damian's Avatar
Nice cam specs, I like that split. To much lift IMO, but a nice stick no doubt. Would make great power N/A and nitrous would kick ***
Josh
Old 12-07-2003, 02:54 PM
SPANKY LS1's Avatar
Josh
It'd be better suited for NOS if it was on a 114, IMO. (Or at least a 112, damn, 110 is TIGHT)
Shawn
Old 12-07-2003, 03:04 PM
LSX Mechanic
Damian's Avatar
Shawn, I agree with you. I have always thought higher LSA's were better suited for nitrous purposes. However i've talked to a lot of SBC chevy guys that swear by 109-110 LSA/ICL's for nitrous use. Either way the cam would kick *** IMO....The 110 would hit a NICE lick...
Old 12-07-2003, 05:02 PM
kumar75150's Avatar
Its a badass cam.
In reality though, whatever big cam you with will give you within 10hp of each other. Just decided when you want to do a cam and pull the trigger. There is only so much research you can do.
Old 12-07-2003, 05:17 PM
SPANKY LS1's Avatar
True to a point, if he was building an all out racecar, power would be all that matters. But, since it is his daily driver (A 2003 Z06, to boot) other factors come into play. Gas mileage, idle quality, driveability, and performance are all equal parts to the equation. IMO, he can't do enough research, putting a large cam in a $50,000 car isn't someting that he should regret a week after it is installed.
Shawn
Old 12-07-2003, 06:21 PM
Beast96Z's Avatar
Sounds like a G5X-1 to me -2 degrees of LSA and -2 degrees of advance.
Old 12-07-2003, 06:47 PM
CHRISPY's Avatar
I thought the specs were 226/234 110ICL?
Old 12-07-2003, 07:32 PM
Ragtop 99's Avatar
looks like a very agressive intake lobe. 607 lift on 228* is a bit faster than an X-ER ramp.
Old 12-07-2003, 09:53 PM
Beast96Z's Avatar
You need the advertised duration to be able to figure out the ramp rate. You can have a 228 camshaft with .607 lift and still have a very lazy lobe. Big lift dosent determine ramp rate.
Old 12-08-2003, 04:30 AM
kumar75150's Avatar
This aint no XER lobe. I havent heard any other cams sound like this lineup of cams.
Old 12-08-2003, 09:58 AM
Roger White's Avatar
My cam sounds nothing like a g5x anything.
I do know its not an XER lobe.
Old 12-08-2003, 12:51 PM
Ragtop 99's Avatar
Beast: I was assuming that the ramp is going to be atleast as fast an XE-R in order to maintain idle quality and that would fit with the strategy used by TR in their "Old Man Cam."
Your defitinely right, w/o the .050 spec, I can't be sure and should have spelled out my assumptions.
Old 12-08-2003, 01:36 PM
distortion_69's Avatar
Isn't the 228/234 the .050 spec?
Peace,
