What to set Preload for on Comp R Lifters?
Old 12-07-2003, 04:14 PM
Bear's Avatar
Default What to set Preload for on Comp R Lifters?
Hey I have been lurking around and I am wonderingwhat the preoad should be. My car is alomost done and I am also using YT rockers. I have seen some problems with cars and YT and whatnot. I have been told by JPR that this wont be a problem and I BELIVE HIM, but what signs should I look for if there IS trouble.
Preload for Comp R===?
Signs of bad YT's====? Thanks Bear
Old 12-07-2003, 06:55 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,090 Likes on 718 Posts
We have mine at .005 lifter preload.
Old 12-07-2003, 07:09 PM
Bear's Avatar
PSJ How many "turns" is that?
Old 12-07-2003, 07:13 PM
Senior Member
Country Boy's Avatar
You cant judge by turns. Youre going to have to break out a mic
Old 12-07-2003, 09:15 PM
DaleMX's Avatar
Your going to have to horse around with the shim thickness to get the preload right. I believe the spec is .000 to .010 max.
Old 12-07-2003, 09:35 PM
Bear's Avatar
Thanks Guys. I will talk to Joe and make sure. Any thought on the YT's?
Old 12-07-2003, 10:10 PM
Unaffliated Racing's Avatar
no..its .030" that is recommended
Old 12-07-2003, 10:12 PM
Senior Member
I was told .000 - .010 by Comp.
Old 12-07-2003, 10:16 PM
Bear's Avatar
I guess I should call myself. There is no room for error. I am sure Joe knows what it is supposed to be, but I wanna be doubly sure. This motor was too much money for me not to make that phone call.
Old 12-07-2003, 11:19 PM
LS1Tech Sponsor
Slowhawk's Avatar
I've been hearing .030 also..000 -.010 is very hard to get and would require each rocker to be checked and shimmed differently.Would be easier to run a solid roller.
Old 12-07-2003, 11:23 PM
Bear's Avatar
WTF. Y is this such a hard thing. I was hoping for an easier time with my "feelings" on this motor. Are these good lifters?
Old 12-07-2003, 11:55 PM
Spinmonster's Avatar
I heard the preload is less on the r's than the regulars.
Old 12-07-2003, 11:56 PM
ok..well you dont have to call....I've just answered your question....shhhhh!
Old 12-08-2003, 08:09 AM
Formerly 4mulaJoe
LS1x2's Avatar
I didn't measure myself. I ran into problems with both stock pushrods(too much preload) and 7.35(not enough). I tried a few different shims. With a .015" shim it was just right. So the answer is not very much at all. I am happy with these lifter spinning up to 7k and more.
Old 12-08-2003, 12:12 PM
white2001s10's Avatar
What kind of symptoms were you having when you had too much preload? Hard starting? or trouble pulling high RPM?
What happens when you have too much preload on stock lifters?
Old 12-08-2003, 12:16 PM
Formerly 4mulaJoe
LS1x2's Avatar
I could just tell the preload was too tight from the sound at idle. It loped like it had only 2 valves in the car. No chop. You distinctly heard one set of valves open, then another set all at the same time. Dunno if that makes any sense, but it is easy to tell.
Old 12-08-2003, 12:46 PM
LS1Tech Co-Founder
"heard"
Comp recommends zero lash to .010 not .030.
I'm not making this up. Call them up and correct me.
Stock lifter preload is .050 FYI.
Old 12-08-2003, 02:34 PM
LS1Tech Sponsor
Slowhawk's Avatar
Most stock lifters I've measured are .100 +.Mostly .130.
.010 would be 1/8 turn preload.
Old 12-08-2003, 02:43 PM
"heard"
PSJ, Suppose you ran your preload to the maximum recommended. Would this possibly require more valve seat pressure from your springs to keep the valves seated?
Old 12-08-2003, 05:06 PM
PHATKOP's Avatar
Question Lifter Preload....Why?
Bear,
Why would it matter what the Lifter preload is when JPR built your motor. Also not to start trash talking, but dyno numbers don't mean nothing. You can have 500 hp and that don't make your car fast. The bottom line is ET.
PHATKOP
