Missing/backfiring and low cooant
Old 10-29-2009, 03:11 PM
bluebyu8484's Avatar
Default Missing/backfiring and low cooant
Random backfiring occurs when I increase throttle off 2-3k cruise. Pulled valve cover and there is a "snot" colored film on the inside of the valve cover. Checked coolant level and it is 6-8 inches below full level. This happened a few miles after I added sea foam, but tank was only 3/8 full. Service engine light comes on randomly for less than a minute. Thank you for any thoughts/advice.
Old 10-29-2009, 03:24 PM
BaddBird's Avatar
sounds like a blown head gasket. pull your plugs and do a compression test
Old 10-29-2009, 04:10 PM
Just checked my catch can and couple inches of water.... this car has been driven rarely and not hard for the last couple years. Did a head swap in '04 with maybe 3K miles since. What would make a gasket blow out of the blue?
Old 10-29-2009, 10:20 PM
ae13291's Avatar
hold on, it cant be a gasket just yet, i remember when i used to drive like short trips like 3 miles a day with my car, my catch can and oil cap was all milkey with water, i soon found out that becasue i was driving short trips the condensation did not have enough time to escape out the engine since the engine never reached full temps. so then i started fully warming up the car b4 i went to school and problem solved, but on my car i dident loose coolent, also check your dipstick if it is really full of that much water it can be a possible head gasket.
Old 10-30-2009, 09:24 AM
BaddBird's Avatar
Sorry man, but condensation wont cause a mis or backfiring.
Old 10-30-2009, 09:45 AM
It is was weird that this issue came up after the seafoam I added with low fill on the tank. Any thoughts on that?
Old 10-30-2009, 12:51 PM
bluehawk2's Avatar
sounds like a head gasket for sure, pull the plugs and tell us what they look like........you could narrow down which side is the culprit.
if you drive it very little, then the milky oil could be due to the condensation, but that's not going to cause you to loose coolant
Are you sure the coolant was full to begin with?
Old 10-30-2009, 04:53 PM
Old Geezer's Avatar
Default Nope..
nor will it cause an 6-8" drop in coolant level.
If the engine has antifreeze in it, continuing to drive it will take out the brgs...
Old 10-30-2009, 08:55 PM
ae13291's Avatar
sorry dident catch that part, yea head gasket now is a possibility, but still seams weird for it to go like that
Old 10-31-2009, 09:23 AM
What are "brgs"? I am not positive on the level prior to this happening, but have checked in the last year and was fine....again I may have put 300 miles on it this year though. The coolant level low indicator has been on, but the radiator was full... figured it was a faulty sensor, which I know is common. How can taking off the plugs tell me if it is a gasket? I guess they should be wet? Also, this snot has coated the catch can pretty good so I am assuming the crap is every where in the engine... when I get this fixed what is the best way to clean the engine internals?
Old 10-31-2009, 09:56 AM
BaddBird's Avatar
He is referring to the engine Bearings "brgs". Pull the plugs to see if you have coolant on any of them. If you run a compression test you will know without a doubt.If it is a gasket failure when you change the gaskets have the heads checked to make sure they are not warped. When you change the oil after the repair that should get all of the contaminated oil out of the system.
Old 10-31-2009, 11:09 AM
Thanks for the clarification. Yes, when I pull the heads I am going to have a specialist check them out and refresh the springs. i will pull the plugs and get back with findings. Thanks to all that have helped me with this.
Old 10-31-2009, 11:26 AM
G Engines's Avatar
if you were to do a leak down that should show you if your hg is blown if you leave then radiator cap off you should see bubbles in your radiator if its a hg.
Old 11-02-2009, 10:57 AM
Got the plugs out and the plug for #7 cylinder is FUBAR. The ground strap is in total contact with the electrode and is twisted counter clockwise about 10 degrees. It completely covered with soot but no real evidence of water. What the heck would have caused the plug to be so screwed up. Again I did the seafoam on a low tank, which could have fouled the plugs. The other plugs are dry and are an amber/silver color, but the "rim" of each plug is blackened.
Old 11-02-2009, 11:12 AM
1CAMWNDR's Avatar
Sounds like you need to pull the driver's head and see if the head gasklet is blown or if you have a broken piston/cracekd block. My valve covers were also covered in snot.
I was planning on changing headgaskets and instead got to buy a new motor:
https://ls1tech.com/forums/generatio...-mile-ls1.html
Old 11-02-2009, 11:18 AM
BaddBird's Avatar
Do a compression test. I understand the need to find the cause but you also need to find out the extent of the damage.I cant see the seafoam being the problem. I clean injecters with 50/50 mix of seafoam and gas through the rail with the fuel pump disabled.Do a compression test and post up the readings.You already have the plugs out thats the hard part.
Old 11-02-2009, 12:21 PM
Has anyone heard of a plug this f'd up? Don't get it... also no coolant leaking from the engine. It also idled fine and can run @ cruise. Will get the leak test done.
Old 11-02-2009, 03:07 PM
1CAMWNDR's Avatar
Coolant is probably leaking into the cylinder and being burnt and sent out the tail pipe. That is what mine was doing. No leaks at all from the engine bay.
Old 11-02-2009, 03:23 PM
With the amount of coolant I have "lost", should I drain the oil/water while I am dianosing this problem?
Old 11-02-2009, 03:35 PM
BaddBird's Avatar
you should be ok to do a compression test without draining anything. Do not drain the oil and whirl the motor over!
