Cam n00b. What's a good one for LS1 w/LS6 intake?
Old 10-31-2009, 01:41 PM
TurboGoKart's Avatar
Default Cam n00b. What's a good one for LS1 w/LS6 intake?
Hey everyone. Kind of new here. Obviously I'll be upgrading springs/retainers/pushrods. LS1 is from a 99 Vette. 1 3/4" LT's, going with an LS6 intake. Just wondering what would be a good cam for me. Car is a weekend type fun car. It's not my daily.
I'd like *some* reliability out of this motor, I don't want to worry about PTV contact, but I'd still like to get the bigger cam lope out of it. Any suggestions? (Will be mated w/a T56)
I've heard/read great things about the Torquer v2 cam.
Old 10-31-2009, 03:31 PM
LS1-NAVY's Avatar
i would say the "el torro" its a 230/230 .612/.592 LSA 111+2 here is a thread for some info https://ls1tech.com/forums/generatio...torro-cam.html
Old 10-31-2009, 04:28 PM
ae13291's Avatar
get a LS6 cam
Old 10-31-2009, 04:54 PM
What's the +2 mean? Does that have to do with how the cam is degreed in? Advanced 2 degrees past stock?
Old 10-31-2009, 05:00 PM
Originally Posted by ae13291
get a LS6 cam
If I'm going to have the motor opened up, I really only want to do it once. If I'm going to spend money on a cam, I want to do it right.
Old 10-31-2009, 05:12 PM
JS01's Avatar
It's ground-in advance.
Old 10-31-2009, 05:42 PM
Zach79Z's Avatar
Vindicator
Old 10-31-2009, 06:24 PM
Vindicator is a big cam. A little too big for an otherwise stock block (minus p/r's, springs, retainers). I'd be a little worried about the rod bolts probably.
Old 10-31-2009, 06:28 PM
JS01's Avatar
What does the size of a cam have to do with rod bolt durability. Just don't rev it super high.
Zach79Z's Avatar
Go wtih ae13291's advice then lol
Old 10-31-2009, 06:45 PM
Sure, but then you don't really get to take full advantage of the size of the cam if you don't rev it. Right?
Old 10-31-2009, 07:44 PM
desertLS1's Avatar
yeah seriously lol
that was a stupid post.."get an LS6 cam" WTF
I also say Vindicator.
Old 10-31-2009, 08:01 PM
You guys running the Vindicator....what other mods do you have done? Other than the obvious p/r's, springs, retainers?
Old 10-31-2009, 09:47 PM
ae13291's Avatar
Originally Posted by desertLS1
yeah seriously lol
lmao hahah asking what cam i should get is like asking oh what tires should i get on my car or what gastation i should buy gas from. its such a open question lol better to just be safe and buy a factroy cam if u have no idea what to get. or pay some cash and fill out the cam form from pat G if u want to do it right.
Old 10-31-2009, 11:26 PM
That's why I posted what I wanted out of the car. So my question wasn't open ended. Not a daily driver, want *some* reliability w/o having to worry about PTV contact.
Not wanting an LS6 cam, but thanks.
Old 11-01-2009, 12:04 AM
ae13291's Avatar
i ordered my cam through Pat G im in the process of installation (still awaiting the cam since its custom grind) but i have everything out and i already did the valve springs. i wanted pretty much the same as what you wanted except i wanted it to be so i can daily drive the car when i want. i will give you my specs of the cam when i finish installation if your interested. if your doing the cam install yourself buy the girdle for the oil pump pick up tube and also put into consideration the new base circle of the cam so you can get the correct length pushrods.
Old 11-01-2009, 06:32 AM
Good info! Thanks! Yeah I'd be interested in your specs. Thanks.
Old 11-01-2009, 07:11 AM
LS1-NAVY's Avatar
with the el torro is a great street cam with a good amount of low end torque compared to bigger cams its also the smallest cam in the top ten fastest cam only cars. all the cars on that list have like the t-rex, ms4, ms3 and so on.
Old 11-01-2009, 08:59 AM
Zach79Z's Avatar
The Vindicator is a great cam only cam and if you decide you want to add heads later on down the road its also great for a heads and cam set-up. I dont have a vindicator in my car but have rode in a 6speed trans am with one and it pulls like a freight train. All he had done to his car besides the basic cam kit was true duals and turndowns. It sounded mean as heck too.
Old 11-01-2009, 09:17 AM
Any idea how long he's been running it? Any problems with it?
Thanks for the good feedback.
