New PRC 2.5 5.3 & V2 Cam install Problem
Old 11-02-2009, 08:50 PM
willystyle438's Avatar
Default New PRC 2.5 5.3 & V2 Cam install Problem
I recently installed PRC 2.5 5.3 heads & V2 Cam and car will idle good when you first crank it. The first time you give it gas it wants to die and sometimes does. I have to play with the throttle to keep it running. I have LS6 intake, PS Race LT's, PS ORY, SLP loudmouth cat back.
I installed new pushrods, timing chain, oil pump, lifters & Powerbond Pulley at the same time.
I know i need to get it tuned.
I live near Houston, can anyone give some advice?
Thanks,
Old 11-02-2009, 09:06 PM
Sorry, it is a 2000 Z28, M6 with new 373's.
Old 11-02-2009, 09:08 PM
tko0383's Avatar
I would try the PCM Diagnostics & Tuning section. Also do not drive the vechicle until you get it tuned.
Old 11-03-2009, 09:27 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
More than likely this will be a tune issue. Did you degree the camshaft in to ensure the VE's were as intended and that the camshaft was not installed a tooth off?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
