24X LS2 Crank In LS1 ?
Old 11-03-2009, 07:52 PM
2xLS1's Avatar
Default 24X LS2 Crank In LS1 ?
Any reason a 24X reluctor 05 GTO LS2 crank could not be used in a 98 LS1 block? My GM parts guy says it is a different part# than a LS1 crank. I've looked at the production dimentions and they seem to be the same. The only thing I can figure is the balance may be different. Any other differences I'm not aware of or has anyone used one in a LS1 with no issues?
Old 11-03-2009, 08:27 PM
DeanJ's Avatar
Some of the truck crank's rear flanges were different. I think all cars were the same . Ballance should be checked, bigger pistons in LS2. Dean
Old 11-03-2009, 09:05 PM
427's Avatar
It is a balance issue with stock replacement parts. You can use it no problem if you balance it to your bobweight.
Kurt
Old 11-04-2009, 06:50 PM
Mrs.Nos's Avatar
SO if we take it to the shop and balance it with my new rods it will work????
Old 11-04-2009, 07:27 PM
2xLS1's Avatar
Sounds like it. You probably should have had your old crank rebalanced with your new rods. Why don't you call the machine shop you are going to use and see what they say about it. Be sure and tell them what rods and pistons you plan on using with the LS2 crank. I know Charlie at Folks Machine in Norman has a lot of experience with Gen 3 motors.
Old 11-05-2009, 09:17 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
That's correct! Take them the pistons, rings, rods, and rod bearings so they can do the balance job right!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Quick Reply: 24X LS2 Crank In LS1 ?
