need help...need oil pan reversed for sandrail??
Old 11-03-2009, 07:54 PM
383camaroSS's Avatar
Default need help...need oil pan reversed for sandrail??
im building a sandrail and need the oil pan reversed...can i just reverse it or do i have to buy a custom oil pan?
Old 11-03-2009, 08:09 PM
DeanJ's Avatar
Is your pan front or rear sump now? If you need a front sump, look at a GTO pan. Most others are a version of the rear sump design, just different sump lengths and depths. I just reread your post, you can't just reverse the pan, for various reasons. Dean
Old 11-03-2009, 08:11 PM
what yr gto?
Old 11-03-2009, 08:20 PM
DeanJ's Avatar
what yr gto?
Is it a LS type engine? I assumed so. If so 04' up. Maybe some of the other Poncho's too, ie, G8 maybe? Never worked on one though.
Old 11-03-2009, 08:33 PM
thanks....
Quick Reply: need help...need oil pan reversed for sandrail??
