Worst case of piston slap ever! 56k=death
Old 11-05-2009, 04:48 PM
Deacon Frost's Avatar
Default Worst case of piston slap ever! 56k=death
Well, after losing compression in several cylinders and sounding like my exhaust was coming out of my intake manifold, I have had to replace my old engine which had only 40k miles on it. Here are the pics form the teardown. Feel free to weep with me.
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
Cylinder 5:
Cylinder 6:
Cylinder 7:
Cylinder 8:
Notice how smooth and glassy the even numbered cylinders are? The odd numbered ones are gouged to hell. I am not sure if honing will even fix the odd numbered ones, especially number one and seven.
Old 11-05-2009, 04:53 PM
Now for the pistons:
I am only going to show the worst ones and the best to give a comparison.
#1:
#7:
The good ones:
#2:
#4:
Old 11-05-2009, 04:54 PM
BlownChevySS's Avatar
Wow!! I guess I have been kinda lucky with my lq9 from the SS with the piston slap issue.
On the bright side, I have seen worse and yours could be worse. Good luck with the build
Old 11-05-2009, 05:05 PM
eseibel67's Avatar
#5 cylinder has a sheet metal screw in it.
Old 11-05-2009, 06:27 PM
It was the only thing holding that piston in the block. A-Team style!
Old 11-05-2009, 06:37 PM
O2Form's Avatar
Let me guess...K&N air filter was used? Looks like alot of dirt was getting in the intake some how.
Old 11-05-2009, 07:24 PM
Cape T/A's Avatar
what oil where you running, those pistons and rings look nasty and rusty!
Old 11-05-2009, 07:41 PM
mathia's Avatar
Yeah, a K&N filter was used for the odd cylinders and a paper filter was used on the evens. Finally conclusive proof K&N filters will destroy your engine in 40k miles or less.
Old 11-05-2009, 08:00 PM
DutchmanZ's Avatar
That is too funny
That #7 cyl looks really bad. I hope you can save it without boring it. If you have to bore, stroke it too.
Old 11-05-2009, 08:47 PM
69LT1Bird's Avatar
Looks more like coolant washed the oil off the cylinder wall causing the piston damage. Slap is usually cold start only and stops when the piston expands.
Old 11-05-2009, 08:50 PM
ae13291's Avatar
ohhh man that was too funny
Old 11-06-2009, 11:56 AM
O2Form's Avatar
I agree they are complete garbage!
Old 11-06-2009, 02:07 PM
bjamick's Avatar
Can't really see to much by the pics, but it can be put back together pretty cheap. Just have it bored out to 3.905, pretty much is just a nice clean-up. Then buy a nice forged piston and rod setup and put her back together.
After having everything balanced of course.
Quick Reply: Worst case of piston slap ever! 56k=death
