5.3L Heads off Tahoe???
Theyre probably 853 heads but they would need to be ported and polished along with valve springs and bigger valves for an improvement. If I remember correctly they do have a smaller combustion chamber as well thats why they make more compression.
We offer a ported 5.3L heads. They start at $1125 with 2.02/1.57 stainless valves and dual springs. 5.3L heads are good for guys on a budget. They move a good amount of air out of a 220cc runner and the smaller (62cc) chamber will make for a nice gain in compression! If you already have the heads, you can send them into us to port as well! CNC porting and CNC valvejob starts at $650! We also have several LS6 stages as well if you decide to go that way as well.
Also, remember going to a '99 and newer cylinder head, you will have to change to the center-bolt valve covers and coil brackets as the '98 cylinder heads are a perimeter bolt head. That way you aren't surprised when your valvecovers don't bolt back up!
Let us know if we can help!
