I learned my lesson on valve springs
Old 11-15-2009, 01:36 PM
AutomagicLS1's Avatar
Default I learned my lesson on valve springs
& that's to change them religiously. Luckily this lesson only costed me a new set of valve springs......live and learn
Old 11-15-2009, 02:55 PM
teke184's Avatar
what were they?
when did it happen?
mileage?
other parts to the valvtrain?
more info
Old 11-15-2009, 02:59 PM
ae13291's Avatar
???? did this happen when installing them?
Old 11-15-2009, 03:03 PM
Restricted User
1BAD_LS1's Avatar
subscribing.... those look like prc duals.
Mileage?
Cam?
we need more info... im interested!!!!!!
Old 11-15-2009, 05:10 PM
02 BLK WS6's Avatar
Cam size, lobe design, lifter preload, brand, and mileage please?
Old 11-15-2009, 05:18 PM
hirdlej's Avatar
This aughta be good. They look like your typical associated dual valve spring setup....
Old 11-15-2009, 06:21 PM
Restricted User
1BAD_LS1's Avatar
well i have a powerloss BAD at 5500rpm ive been chasing... I have the PRC duals, I wounder if mine are getting worn out after only 8000 miles....
I know i deffenetly dont want them to get that bad!
Old 11-15-2009, 06:50 PM
matrik's Avatar
Waiting for info as well. I feel I have a powerloss in the upper rpms and I have the PRC duals as well!
Old 11-15-2009, 07:03 PM
G Engines's Avatar
when a valve spring isn't pushed close enough to coil bind it creates harmonics. drastically shorting the life of the spring. This could be a result of such a thing. A spring that is run .060 to coil bind will far out live a spring that is run a .160 from coil bind,
Old 11-15-2009, 07:08 PM
02 BLK WS6's Avatar
My car has a Lunati Grind 231/237 .595/.598 on a 112lsa and I've ran these valvesprings for 12k miles without issue. I'll be replacing them soon, but only b/c I'm installing ported heads.
http://www.compperformancegroupstore...egory_Code=BEE
Old 11-15-2009, 07:33 PM
Restricted User
1BAD_LS1's Avatar
I ran my prcs.... cam only with a 227/231 614 617 112+2, then i got an sts kit and ran the same cam and springs, now im running them on my setup in my sig!
about 8000 miles total but i lose 100hp after 5500-6400... and cant find out why and am thinking maybee it the springs are wore out and giving valvefloat maybee.
If the springs are about the mileage mine are im deffinetally gonna change mine!
Old 11-15-2009, 07:58 PM
G Engines's Avatar
It may be that you springs have fallen off or you may be flexing your push rods, you may want to go to a larger diameter push rod if that isn't an option use a haver wall push rod.
Old 11-15-2009, 08:05 PM
Mighty-SS's Avatar
I've seen that many times... I wonder if there is a problem with the PRC's ???
Old 11-15-2009, 09:32 PM
I will make a detailed post later on. I am replying from my cell phone. They are patriot golds. They did have some good miles on them. It all started a few months ago When the car wouldn't pull passed 6500 it was like the tranny I had was hurt. Upon more test it ruled the trans out. I'll make A more detailed post later on tonight when I get to a computer
Old 11-15-2009, 09:45 PM
Restricted User
1BAD_LS1's Avatar
good deal... sounds like my problem cant hardly pull past 5500. lol
Old 11-16-2009, 02:50 AM
Nitroused383's Avatar
Well looks like you ran them on a LSL lobed cam. I will almost guarantee your valve springs are wrecked at 8000 miles. The PRC springs are known to sag over time and with that much mileage on a set of lobes known to wipe out a few valvetrains I imagine it to be the culprit.
Old 11-16-2009, 07:47 AM
SLOC5LS6's Avatar
I've had my PRCs for 25k miles. I need to be looking into replacing them also
Old 11-16-2009, 08:51 AM
PREDATOR-Z's Avatar
I DD my PRC platinums for 3 years now, 1 racing season and 3 cams; all over .600 lift and they are still within specs.
The issue poeple tend to miss is *Were the springs installed at correct height for cam used?*
Old 11-16-2009, 08:57 AM
Z28boy2000's Avatar
woah thats bad, im replacing mine this winter just as precaution after 12k on the cam swap
Old 11-16-2009, 09:31 AM
TooLateVTEC's Avatar
Thats the million dollar question...
Quick Reply: I learned my lesson on valve springs
