Forged pistons for the 4.8/5.3L bore???
Does anyone make them, or should I get rid of the 5.3L and get a Lq4?? By the way it's for a FI application and I would want somewhere around 8.8-9.0 CR
LS1Tech Premium Sponsor
Wiseco makes a piston for the stock bore and .020" over bored 5.3L engines with the stock 3.622" stroke and 4" stroker crankshafts. The stock stroke pistons are a flat-top 2.2cc valve relief. The stroker pistons are -7cc dished.
With either of those, you'd be looking at a head swap to get your compression that low. Are you going to be running a crazy amount of boost? What power goals do you have? That's pretty low compression even for a moderate boost combo!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Couple of questions....
Where will the compression be with the stock stroke wisecos?
Can i get a HG thick enough to put the CR back to stock or less?
What cam would you suggest for a turbo 5.3L with a glide and a 3600 stall?
I just don't want to have to run race gas all the time. The low compression was intended to keep me on 93 octane up over 10psi.
Please remember I come from the world of turbo 4cyl were it takes 20psi to get 400whp I'm sure there will be a learning curve for me.
Putting a 5.3L in a 240sx with a glide. Car will be registered but rarely street driven. My power goals are based on 15-18psi through a BW S475. I have a free motor with high miles that I want to have built to last. Initial thoughts were forged pistons, rod bolts, arp head studs, mls gaskets, ported 5.3L heads and MS3 cam.
You could do a set of heads with a 72cc combustion chambers and the -2.2 relief that matt posted about and be in the low 9:1 compression. Just get a meth kit to keep the detonation from happening. 93 and meth will be fine for 15-18 #'s of boost. I make 11#'s right now on 91 octane 17 deg of timing and no detonation. This winter i'm adding meth and a smaller pully to hit 15-16 #'s, not worried one bit.
