Engine Assembly questions
Front and rear cover alignment. Does someone have a link to a procedure for setting them up without the $400ea tools the service manual procedure calls for?
This is on a brand new block with new covers.
Thanks.
Thanks.
If you are talking about the timing set cover, there is an easy procedure that requires no special tools. Have the seal already installed in the cover, and the crank already installed. Put the cover on with just a bolt or two put in loose. Then put the pulley on the crank. Now you can put the rest of the bolts in and torque them down. This will insure that the cover is centered around the crank so it doesn't leak oil.
Senior Member
Just to add to this... Youll HAVE to make sure the spacing is even where the bottom of the cover meets the oil pan rails. Too much space on one side and you may have a oil leak.
Its thats simple?
So install the crank, put the front cover on with a couple bolts, install balancer, then align the bottom part of the front cover so its even, then tighten down, then install the rear cover?
So basically we are using the seals to center everything?
Senior Member
Originally Posted by Heretic
Its thats simple?
Senior Member
Also, install the front and rear main seals DRY... do not put oil on them or the crank surface. They are made to be done dry as they contain teflon which "melts" to the crank and forms the seal so you dont end up with the front and rear main leaks. Also, again, I think you put the rear main on AFTER the cover is done, not before. Id have to look it up again to be sure.
Originally Posted by 4mulaJoe
This is funny. I've done this numerous times and didn't do anything special. I slapped it on and re-used the gasket. No leaks.
Never done a rear cover (yet) but I have done the front cover a number of times. I just slap it on, bolt it down, and 25K miles later is was still without any leaks.
