pushrod/ lifter preload
Old 11-17-2009, 07:19 PM
livefast1's Avatar
Default pushrod/ lifter preload
factoring in a 7.425 pushrod i come up with .066 preload on the intake and .0543 preload on the exhaust (different size base circles). is this enough or should i go up another .025 to a 7.450?
Old 11-17-2009, 10:28 PM
68 RS Convertible's Avatar
what lifters are u running? are those preloads an average you got from measuring all of them or did you just measure one of each.
Old 11-17-2009, 10:33 PM
livefast1's Avatar
factory lq4 lifters thats the preload i got, averaged per intake and exhaust seperate and then added .025 to that number for a total of a 7.425 pushrod. should i order 7.45s instead for more preload? i'm not sure on the spec, or what you guys run. guess i could check shopkey in the morning.
Old 11-18-2009, 11:13 AM
livefast1's Avatar
? nobody has the lifter preload spec?
Old 11-18-2009, 12:32 PM
someone correct me if I'm giving bad info. ls7 lifters like anywhere from .060 to .080 preload with a max of around .100 preload. I would think that those numbers would also be in the ballpark for lifters for an lq4. I think that if you have .066 preload on the intake side your good, the .0543 should be fine, unless you get two sets of pushrods, two different lengths to get a bit more preload on the exhaust. your not going to hurt anything by running the .0543 on the exhaust side, imho, but it may give you a little more noise.
Old 11-18-2009, 05:24 PM
livefast1's Avatar
k sweet i will probably just go with a set of 7.425s then thanx for your help
