Newer Lq4 Pistons In Older Lq4???
Old 11-18-2009, 02:18 PM
00sierra4x4's Avatar
Default Newer Lq4 Pistons In Older Lq4???
I have a 2002 lq4, i cracked a piston and want to install a set of pistons and rods from a 2005 lq4. im worried about piston and rod weight if maybe i should get it balanced? and if the crank will work fine with these rods? they are both lq4s but just different years.
anybody run into this? any ideas?
Old 11-18-2009, 06:31 PM
anyone??
Old 11-18-2009, 07:37 PM
jmm98LS1's Avatar
If the newer set has floating pins then you will need to rebalance the crank. The LS2 style rods with floating pins ('05+) are significantly heavier (~20grams IIRC) than the earlier press fit style. Do you not have access to the '05 crank?
Old 11-18-2009, 08:03 PM
i don't, i guess i will try to find a crank it would be cheaper than getting it balanced.
