TSP custom 231/237,.589"/.595"112
Can I run this cam W/ stock heads without a problem? and the comp 918's.
thanks
I have a 02 Z28 A4 my mods are :
3200 stall
NX 100 shot
PCM Tune
Pulley
Lid
Borla
Nittos
I currently 12.2's @ 111 with these mods (I dont have any nitrous
passes)
thanks
3200 stall
NX 100 shot
PCM Tune
Pulley
Lid
Borla
Nittos
passes)
I ran that cam on stage II LS6 style heads for about 2,000 or 3,000 miles with 918's and stock retainers. You'll be fine with them. I spun mine to the 6,800 rpm limiter several times. You should really pick up alot in the 1/4 with that cam.. it is one bad SOB.
Originally Posted by Damian
Sorry to get off topic, Gomer do you not have that setup anymore? I notice you're using past tense. Happy late B-day BTW
josh
josh
so would this cam work alright with what i am wanting to do...
would my 3.23's be alright with this cam ?
my buddy want to sell him 216 / 220 .525 / .532 114 LSA comps cam to me for 200. I dont know what I really want to do!?!?!
This cam seems like it for a heads car.
No, you'll be fine on stock heads. TSP has done quite a few cars with this cam and stock heads. I will STRESS that you WILL need a pretty good stall, especially since you are going to keep your 3.23 gears. I am still running the 3.42's in my car and I don't have any surging or anything cruising along at low RPMs in 6th gear. This cam is a big cam and there will be ALOT of difference in how the car drives with it compared to the stocker.
Nice.....Power increase?
It feels like the midrange is a good bit stronger, maybe a little at the peak too. I'm afraid to get too excited until I dyno it again next Friday... It may just feel that way because I had to drive my maxima so much while the heads were off the car But the "max" got it from behind last Wednesday in a nasty crash Damn women drivers.
3200 stall enough ?? more like a 3400
I emailed TS and was sent this
Paul as long as you dont mind tuning I would run the 231.237 camshaft, it really shines on nitrous setups. The 114 is doable, but I usually go 112
Jason
Jason
A friend of mine has the 231/237 cam in his A4 (stock heads with 918's) with a TCI 3500 and 3.73's and his drives pretty well, he had the 3.23's in it with the same stall for a while and said it wasn't too bad (didn't surge much). He is about to go with a bigger converter though. He drives it ALOT and has had good luck with the 918's so far as well.
!LS1 11 Second Club
Originally Posted by CamaroCain
any track results?
12.1 @ 116 on a 1.8
I have a stock clutch and 4.10's in the 10 bolt, so launch and shifts were very conservative. I also shifted at 6400 when I should be shifting at 6600-6800 to milk this cam's potential. So, a high 11sec car w/ this cam w/ stock heads on drag radials is very possible.
Originally Posted by SouthFL.02.SS
12.1 @ 116 on a 1.8
Anyone here in Texas with this cam w/stock heads have any track results??? Need some good comparisons...also in some A4 cars.
Restricted User
I only ran 12.31 @ 109, 1.6, A4 @ 3550 with driver, DA 2000+/- , 3.23's and a 3000stall, AFR about 12.9:1 and 25.5* timing (tuned a little more for nitrous) Hoosier Drags, with suspension! I will say our track sucks but I hope our track sucks more than I think. On my old TR224 I ran a 12.38 once, awesome weather that run, all else the same except the 60' was a 1.53.
Charlie.
Charlie.
