New Numbers, Before and after Wide Oval manifold and TB, w/G5X-3
New numbers with G5X-3 package
Well I had to put a new stock shortblock in my personal car, so I installed a used trade in Z06 short block with our G5X-3 cam. I stuck a set of LS1 C5 LGM ported heads with 11.4 compression. I didn't have a set of LS6 heads. I used them all on customers cars.
We installed a set of our LG Pro Long Tube headers ( you know, the ones that cant make big power) and a Borla stinger.
The car has a Black wing and our carbon fiber air bridge. The rear tires are 335/30x18 with 35 lbs pressure. Full belts are on the car with an underdrive pulley and 342 gears.
478.4 rwhp and 440.8 rwtq
The car has stock rockers, and on the before numbers it had a stock intake and stock throttle body. It pulled a very satisfying 458rwhp 422.8 rwtq before the big oval intake. Then after the new manifold install it pulled 478 rwhp 440.8 rwtq.
Have you ever seen this kind of torque on a stock bottom end car???
We have a Mezeire pump coming which should yield another 10 and with the belts off there should be another 5rwhp. Sounds like JC Whitney hp addition but that would make 493rwhp then we can add the LS6 heads
So, I would say that LG PRO Long Tube 1 3/4" headers can make the big hp numbers as well as the BIG torque numbers.
Thanks
Lou Gigliotti
LG Motorsports
Image size edited by jmX....Original sized image here: http://web.ics.purdue.edu/~lgigliot/LGM/LGM478.jpg
Thanks
Lou Gigliotti
LG Motorsports
Lou, all I can says is strap it down at Thunder.
Had to say that before someone else did...just a little
Actually that the most incrediable stock short block dyno graph I've seen. With the LS6 heads and other stuff...this might be the first 500rwhp stock short block LS6!
LGM
LGM
Lou, I scaled the image down and re-hosted it so its easier to read the post.
So tell us more about this wide oval thing...I guess I missed the post about it. 478rwhp is amazing!
that is the TPIS oval intake and tb. It is 88mm wide and 76mm top to bottom. I think the Fast 90mm intake will be better. And even the 78mm round TB fast intake will be almost as good.
We knew that our packages were hurting for air but this was a surprise. The manifold and TB without cores was just over $2000. And with that price, I am looking forward tot he Fast intakes to be released. I have plenty of them on order just like all the vendors.
LG
LG
JEEBUS CRONK! I will be happy with those horsepower numbers from the blasted 427 I am building! You guys never cease to amaze.
Ah and all those who will post up saying "take it to the track, get some real numbers" can rest assured he will be able to pass many peoples asses at 160+ mph on the back stretch of Texas World Speedway just fine.
Senior Member
I bet you guys messed with the weather station. Theres just no way in hell you can do those type of numbers. I bet theres a whole lot more you arent telling!
JFWY Awesome numbers!!
LG
LG
Was the tuning changed from the stocker & for the new TPIS intake & TB???
