Cheap 4" head gaskets?
Old 11-23-2009, 08:25 AM
Isolde's Avatar
Default Cheap 4" head gaskets?
Anyone know where to get any? $73 each is just not fair pricing.
Old 11-23-2009, 09:26 AM
deadmanTA's Avatar
I got the 3 layer MLS from thunder Racing about 2 yrs ago for like $37 each. Their a sponser (TR logo) ---->
Old 11-23-2009, 11:17 AM
NemeSS's Avatar
tr has them like 80$ pair last time i checked, also sdpc
Old 11-23-2009, 11:35 AM
dmiz0420's Avatar
autozone has .042 Mr Gasket that I used for less than $27.99 each. They are right and left specific: 5714G and 5713G. They also have felpro in stock thickness for less $$.
The Mr. Gaskets sealed where Cometic did not. I don't understand how Cometic get away with charging $120+ for those, especially when they have sealing issues.
Old 11-23-2009, 03:28 PM
Isolde's Avatar
Thanks guys!
Old 11-23-2009, 04:31 PM
1CAMWNDR's Avatar
Cheap and head gaskets don't belong in the same sentence. I have never had trouble out of the 2 sets of Cometics I have used. Nor did they cost $120. You might need to shop around.
Old 11-23-2009, 05:21 PM
Isolde's Avatar
Re: Cheap 4" head gaskets?
Quote:
Originally Posted by ploegi
"cheap" and "head gasket" in combination really doesn't sound like a good plan to me......
GM's own composite 350 head gaskets, the $18 each kind, have held over 550 HP, and the early LS1s came with the same style of gasket, so why would I want MLS at 4 times the price? My LQ4 is getting a compression bump, but I'm at 4500 feet, so it's like stock compression at sea level. This build will not see any nitrous or boost, so I'd be lucky to hit 500 HP. HotRod or CarCraft did an LQ4 with the GM "HOT" cam, and got 483 hp at 6000 rpm from an early LQ4. Those iron heads have the same ports and valves as the LS1 heads I'm wanting to install.
So, my dynamic cylinder pressure won't be high enough to need MLS. Now, I've found composite gaskets for 3.9" bores, but that won't work on my block.
Old 11-23-2009, 05:22 PM
Isolde's Avatar
besides, 483 HP at sea level, corrected to my elevation, is 401 HP.
Old 11-23-2009, 05:28 PM
Isolde's Avatar
GM says the pistons are supposed to be 0.008" out of the cylinders at top dead center, so an 0.042" gasket is really pushing my luck with stock rpm, let alone reaching for 6500 rpm. Ive seen piston-to-head collision with 0.031" clearance and 6500 rpm, using all good forged aftermarket parts.
Old 11-23-2009, 05:53 PM
Rick_Vor's Avatar
Go with the GM 5 layer MLS gaskets. .051 thickness and 4.020 bore. Proven winner and a deal from SDPC. Part #12589227. Their site is tweaking at the moment but they ran about $40 each when I bought them a couple months ago.
http://www.sdparts.com
Old 11-23-2009, 10:27 PM
01ssreda4's Avatar
Gotta agree on this one......
Old 11-23-2009, 11:14 PM
Jeep09's Avatar
is it worth the $$ for cometic gaskets? LS1 with a cam and LS6 manifold
Old 11-24-2009, 05:47 PM
Jon@Texas-Speed's Avatar
We have the GM MLS gaskets on the shelf. I believe they are just under $40. Let us know if you need a set!
Jon
Old 11-25-2009, 02:18 PM
Isolde's Avatar
Thanks Rick, this seems safe for thickness, without being excessive, and the bore sounds perfect.
Old 11-25-2009, 02:19 PM
Isolde's Avatar
Scroll up to reply #7, wherein I explain my lack of dynamic cylinder pressure.
Old 11-25-2009, 02:21 PM
Isolde's Avatar
Jon
Thanks, I probably will, because I have a TSP cam on my short list of cams. Which started at about 16 cams, and is currently down to 6.
Old 11-25-2009, 04:57 PM
ramdaspadhye's Avatar
Just an fyi, these aren't 4" bore... They're for an LS1, not an LQ
Old 11-26-2009, 10:44 AM
Isolde's Avatar
Even though I decided against them, I appreciate you clarifying.
