help me diagnose this problem.......
Old 11-24-2009, 09:23 AM
VGLNTE1's Avatar
Default help me diagnose this problem.......
So my buddy has a LS6 CTS-V with a cam. all else stock.
The car was hamemred on through 2 gears, and then a loud knock came. He drove the car home easy and said the knocking went away at 1900 RPM but every other rpm band had the knock. OIl pressure was fine.
We checked the valvetrain. all seemed ok. We then pulled both heads and there is nothing wrong with the pistons or any scoring on the cylinder walls.
We then drained the oil. The magnetic drain plug had almost what lookedliek anit-sieze on it. I think it was metal that was so fine you couldnt even feel it. But after it was wiped off, it had a graphite, lead look and feel to it. Is this bearing material?
Also, how do you check if a lifter is bad?
Old 11-24-2009, 09:31 AM
uwood's Avatar
I was just getting ready to post for the help.
Few more facts.
228/230 116 cam
7.4 Push Rods
Patriot Dual .650 springs
Stock everything else.
Car idled fine, and great oil pressure. It sounded like a shoed horse prancing down the road with a squeal mixed in occasionally.
Old 11-24-2009, 10:24 AM
TooLateVTEC's Avatar
Well, im gonna say its most likely a rod bearing.
That **** on the drain plug is probably bearing material.
At what RPM did this happen? Was a gear missed and it over reved?
Get ready to pull the motor out.
Old 11-24-2009, 10:58 AM
uwood's Avatar
It was around 6600 in 2nd and 3rd before I backed out. I never bounced the limiter.
Old 11-24-2009, 12:37 PM
VGLNTE1's Avatar
this car was also 13.5 AFR. I imagine the detonation took out a bearing. If there is no visible damage or marks on the crank, rod jouornal, are these completely reusable?
