PRC 2.5 LS6 Heads/Cam Combo's Flycut Question?
I need to know with my heads which cam can I go with without flycutting.
Stock LS1 Shortblock stock bore
PRC 2.5 LS6 Heads 2.04/1.6 64cc
These are the cams i'm looking at:
G5x4
Torquer v3
MS3
F13
or your input on a cam that I can use without flycutting.
G5x4
Torquer v3
MS3
F13
Maybe the F13-that one is closer to a Torquer 2 specs. All the others people cut what is needed. I am running those heads with a MS3-But with a -4cc piston. There are a few methods posted here on checking PTV clearance to be sure. Also what gasket are you running and have the heads been milled?
